Question about Janome 1600P-DB Mechanical Sewing Machine
1471 Pfaff sewing machine will not reengage needle
Hi I took the stop wheel loose on my machine and when I put it back together I cannot reengage the needle. Did I loose a spring or something? Thanks, Susan
  • 1 more comment
  • susiecu1 Jan 25, 2008
    Here is a picture of the gears, One black and one white, am I missing something?
    Can someone help? Thanks
  • susiecu1 Jan 26, 2008
    No , I don't believe I have a push dial. The picture is the guts and then I have a disk that cover that and a screw with a spring holds it all together. Thanks for the answer though. Susan
I have a similar probllem except that I have the spring but am not too sure where it goes.
Posted on Aug 05, 2009
Possible solution...when you reassemble, the spring needs to lie flat in the channel under the center black slide. When you put the cover back on,the pin or post that sticks up on the black slide has to be in the curved cam slot on the inside of the cover. If it isn't the slide won't move in and out of the slot to engage the main drive.
Posted on Feb 28, 2009
  • smokey_1944 Feb 28, 2009
    On reconsideration, the spring may not lie flat, but may go elsewhere...guess I'd better work on that. Sorry!
I took batteries out of my Pfaff 1471 without turning it on now I can not get it to do anything but a straight stitch? Did I loose all memory or what?
Oh NO! if you don't turn on the machine first, you will lose what's stored in the memories.
Sorry you will have to put them in again, the same way you did it before. Nuts!
Feb 06, 2018 | PfaFF Sewing Machines
Pfaff 1471 frozen. Button lights on, nothing works; frozen.
UNPLUG it from the wall wait a few minutes and plug it back in .if this does not work contact Pfaff tech support
Sep 15, 2015 | PfaFF Sewing Machines
How to put the belt back on the Wheel of Pfaff Creative 1471
Opening the case voids the warranty, so take it back to the shop and let them do it.
May 20, 2014 | Sewing Machines
My pfaff 1471 sewing machine keeps breaking the needle
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
6. Check top thread tension
May 28, 2012 | PfaFF Sewing Machines
Needle plate on Pfaff 1471 - removed to clean, when I try to put it back on it keeps popping back up. Is there supposed to be a
check to make sure the bobbin is seated correctly in the bobbin case & then try the bobbin cover, it's suppose to click or snap in
Mar 30, 2012 | PfaFF Sewing Machines
My pfaff 1471 shaft with needle will not go up and down it is locked and what ever I try doesn't solve the problem. I have tried unlocking and locking the wheele but nothing seems to work. How can I take...
Undo the screw in the stop motion wheel, then unscrew the stop motiuon wheel, turn the 3 pronged washer intoi a different position, put the stop motion back and the stop motion screw and test, if that does not work move the washer again.
Aug 10, 2010 | PfaFF Sewing Machines
Skipping stitches and sometime the thread breaks.
Sounds like a tension problem maybe. Too tight tension will bend, and break the needle, especially if sewing fast in free machine embroidery, in this mode, the tensions have to be looser anyway. I can't explain why the wheel flagged and stopped, but experiment with tensions first.
Mar 27, 2017 | PfaFF Sewing Machines
While sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Feb 05, 2009 | Brother CS-6000
Janome 1600P-DB Mechanical Sewing Machine Logo
203 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
