Question about Nokia N95 Cellular Phone
Problem connecting to answer phone
Every time I hold down the 1 key to contact my answer phone the screen turns off for approx 5 seconds and then it reverts to the nokia opening screen and boots up. Does anyone know of a possible reason?
    Scholar:
  • 93 Answers
Yes it seems your firmware (software) became corrupt. You should first try a master reset. If that doesnt work, go to the Nokia website and do the software update, flash your phone. Worst case, you have to go to a nokia service center and they will flash it for you right on the spot. If you need more help, just goto my profile and im sure we can help you.
Posted on Jan 25, 2008
I have a Jabra Clear that won't match up with my phone
The first thing I'd suggest you do is to turn your cell phone off and, if possible, remove its battery for 10 to 15 seconds. Then replace the battery and turn the phone back on. If taking the battery off the phone is not possible, simply delete everything on the Bluetooth pairing memory. Also, we will need to reset the Jabra headset to the factory settings.
Turn the headset ON. Then press and hold the volume down and answer/end buttons at the same time for approx. 5 seconds until the battery icon and Bluetooth® icon flash 5 times simultaneously - then the pairing list is reset.
Turn the headset OFF. The next time you power on, the headset will go into pairing mode as the first time you powered your new Jabra headset on.
Once in pairing mode, your cell phone should be able to add the Jabra headset as a new device from within its Bluetooth menu.
Nov 11, 2014 | Jabra Products - BT2080 Monaural...
HELP ME PLEASE!
Option 1. Just take the back off and then take the battery out. Put it back in and put the back on. Press the power button until you see the green android thing then let go. It should turn on.
Option . Held the volume down button down then while continuing to hold it down. Hold down the power button and nothing happened after about 45 seconds so just let go off the buttons
Option 3
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically,, you need back up all the datas and contacts to SD card before performing reset on your device this method will delete all the datas and contacts.
Jul 19, 2013 | Boost Mobile ZTE Warp Sequent Touchscreen...
My samsung galaxy pocket won't turn on!!
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 29, 2012 | Cell Phones
Vauxhall corsa says SAFE how do i unlock please
Here is how you unlock it:
1) Turn radio off
2) Start engine
3) Press and hold down AS button
4) Turn On radio WHILE holding down the AS button until there is a beep
5) Dial the code using the 1, 2, 3, 4 keys (eg: 1234 would be 1 once, 2 twice, 3 three times and 4 four times)
6) Press and hold AS button for approx 5 seconds
Mar 02, 2011 | Car Audio & Video
My phone locked wont take my gmail information.
Hi Amarie,
My name is Ryan and I work on behalf of Cricket. You may try a set of options below. If you continue to experience issue logging into your phone, please visit a full service corporate Cricket store for direct hands on assistance with unlocking your phone.
Best,
Ryan
1. try to introduce as a null password. (Together with your Google user name)
2. re-enter your user name without@gmail.com
3. Combine 1 and 2
4. You call yourself from another phone, the answer, hang up, press the start button, then menu button, settings, try to disable the blocking pattern
5. You call yourself from another phone, answer, hang up, hang up immediately after pressing the start like a madman for 6. Try to restore the normal routine GMail.com password and start again from 1.
7. Perform a factory reset. Lose all non-synchronized DATA (SD card is left intact.)
1.6 are possible solutions, these do not work for everyone, but it may be worth trying to avoid factory reset. 6. is what should work, but hardly ever. 7 - factory reset always works
Final Update
In this case the solution is to do a factory reset (sometimes referred to as hard reset or wipe). This will erase all data on the phone (not your SD card). Your contacts and email should be in line with Google's servers, no problem then. The downloaded applications should be installed again, but there is a list of your previous downloads in the Android Market-> Downloads Mi. Also if they are lost if not backed up manually with a 3rd party application. Example of things that are lost: Call logs, text messages, application settings.
This is your three-step solution
1. Factory reset the phone (links to manuals Android devices can be found below, differs between devices)
2. Setup phone like you did the first time I unpacked it (use the same Google account if you want your old contacts again!)
3. Restore any backup manual and install the above applications from the list of My Downloads.
If above does not work, please try additional reset steps -
This document is intended for end users, retail stores, authorized service centers, or companies who have forgotten the ZIO block pattern and have not yet registered with Google, or forgot the Google Gmail account and password.
WARNING: This process will erase all user settings and downloaded applications. Data on the SD memory card and my backup is maintained. Before following the steps below, make sure the phone is off.
1. Turn off the phone.
a. Press and hold for 2 seconds red end> Options> Phone>> select Shut Down>> phone will turn off>> Ok
a)
2. Remove the battery for 15 seconds and change the battery.
3. Turn on the phone.
a. Hold the red END key for 2 seconds and wait until the device turns on completely.
b)
4. Turn off the phone.
Procedure, cont.
5. Press and hold the Volume Up button using the left thumb.
6. While holding the volume up key, use the right hand to press the green Send key, the track ball white and red end key (sequence).
7. Continue to hold the 4 keys to all the way down until the phone vibrates twice and then release the keys and trackball.
a. And data format appears Cache
1. If you do not see this (and cache data format) redo steps 1 through 7.
2. If you get a quick start self-test, or the blue screen redo steps 1 through 7.
8. Allow the phone to completely reboot. This process may take some time.
9. The phone has been re-set the factory default settings. Please proceed through established standards and procedures for activation.
NOTE: If a self-screen or blue screen, complete restoration was done incorrectly. Please try again from step 1.
Feb 12, 2011 | Kyocera Zio M6000 Cricket
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
How to format the nokia n81
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and ‘3′ button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message ‘Formatting’ appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
Sep 04, 2010 | Nokia N81 Smartphone
When powered on start up is up to windows screen only
try to hard reset your phone to return to its factory setting, but please be reminded that this procedure will lose all your user settings, data such as contacts, messages etc,. so we always suggest to back up your phone first,. but in your case, if your phone doesn't open normally there is no way you can back 'em all up. better to sacrifice the data than sacrificing your phone. :)
to perform a hard reset.. 1. Press and hold both soft keys 2. While holding down soft keys, press and release the power button, wait for 3 to 5 second (this time phone should power itself on) 3. Release both soft keys 4. when the screen looks like it is on dos format, press the green key (send key or answer key)
if not successful, repeat the steps....
Jul 26, 2010 | HTC S620 Smartphone
Cell phone wont turn off
5.Wait 10 seconds.
Step
Thanks
Jul 08, 2017 | Audiovox CDM8940VW
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Make sure that the headset is on.
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
