Question about RCA P52937 52" Rear Projection Television
Rca projection tv
My screen on my rca tv model P52929 is cracked, where can i purchase a replacement screen from?
  • 579 Answers
MCM electronics 800-543-4330 $197.77 p/n 240793
Posted on Jan 25, 2008
Curved, blurry picture on RCA projection screen tv
Thats usually caused by the STK730-130 IC which is located on the Convergence power supply board. Replacing that may solve the issue. You can get the STK730-130 at www.tvrepairworld.com under the Integrated Circuit catagory.
Jul 23, 2011 | RCA P52929 52" Rear Projection Television
Hi I have an RCA TV Model# P52929 that is not turning on for me at all what so ever.
FBT flyback Transfomer 239111 Ck your hori output Transistor also. Call Mats Electronics for Parts 1-800-628-1118
Dec 21, 2009 | RCA P52929 52" Rear Projection Television
My big screen was working and then just turned off and all i get is a click from the power box what do i do to fix this and what parts do i need it is a 52" rca tv model P52929 i really like my tv and dont...
The cicking sound comes from the relay starter . Its like a Fluro tube starter.It is tying to start but because it is damaged can only witch on and off without firing up the display. There may be other parts associated with this when it fails and is not really a DIY job if you are not into electronics
Aug 27, 2009 | RCA P52929 52" Rear Projection Television
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
Alighning tv
i have an alinemenet problem with my rca tv P52929 i went to the book and it said to go to the menu and select 3 which is the screen menu then select option 6 which is the adjust projection tv. this is suppose to allow you to adjust the the tv's three colors. it says to select the green centering to adjust the green tube. blue for the blue and red for the red. it says to center the green first then adjust the red and blue tubes until the test pattern on the tv screen appears white. i hope this helps you. my problem is that the program is not in my tv. it has everything else but not the option 6 to adjust the tv. this may be your problem to. good luck.
Apr 15, 2007 | RCA P52929 52" Rear Projection Television
RCA P52929
go to the menu select the screen option 3 and then select option 6 . adjust projection tv. green is for green use it first then adjust the red and blue until the patterns on the tv screeen appear white.
Sep 26, 2006 | RCA P52929 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
91 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
