Question about Panasonic FP-7750 Black and White Copier
Error code e5-23
Got this error on the front panel and it's all chinese.
Any thoughts?
Thanks
  • drummerjim Jan 25, 2008
    Thanks, I found another site that said it was the sorter, I un plugged the sorter and replugged it in and it seems to be working. With any luck it will stay up.
    I found another site that said the sorter, I un plugged it and re plugged it in and it seems to be working, With any luch it will stay up un less all I did was shake the machine enough for a loose connection in the system
    Thanks
    Jim
  • 25 Answers
That's a "Control panel communication abnormal" error. That could be anything from a loose connector under the control panel to bad control panel boards or any of the boards in the back of the machine. If resetting the power doesn't take care of it, it might be toast.
Posted on Jan 25, 2008
  • Mitch S
    Mitch S Jan 25, 2008
    Gremlins! They are everywhere.
Error codes on a front load washer
Hello friend, thanks for your post!
From my understanding you would like a list of error codes that apply to your Frigidaire washer. Is there a specific error code you are searching for? I was unable to locate a list of all the codes that would be available within your washer, ATF7000E. With additional information I would be able to assist you further. -Matt
Feb 14, 2015 | Frigidaire Affinity ATF7000E Front Load...
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
May 07, 2014 | Zanussi ZWF1640 Front Load Washer
My 3 1/2 yr old unit stopped working completely at almost the end of the cycle. When I went to take out the clothes they were still wet, thought it was the spin cycle so I tried that and the machine...
Hello Anne, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the issue could be related to the door switch or control board. However, first let's try recalling the error code by waking the unit and wait approximately five seconds. Then press and hold CANCEL and START/PAUSE key at the same time. Error code should display. With the error code I can help you determine the possible failures.
If the washer does not display an error code, reset the washer. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes, turn the unit on and redo the steps above.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you!
Sep 25, 2013 | Frigidaire Affinity ATF7000E Front Load...
I am getting an F06 error regularly when trying to wash. What does that error mean?
hello,
what this code indicate on the screen is that there has been an over floe of water on the panel of the washer i.e the the power distributor to different unit of the washer.
thanks
Sep 29, 2010 | Kenmore Elite 45986 Front Load Washer
Heating elements will not heat and getting an error code E1 F-5
Hello,the lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed screw driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Thanks
May 30, 2010 | Whirlpool Ovens
Error code dl
Hello,he "dl" error code indicates a problem with the door latch assembly.There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Thanks
May 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Error F21 with humming sound, then goes to Error 5d
Yes, your F21 is a clogged drain.
Remove the front panel. Unscrew the drain cap and clean it.
Apr 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Panasonic FP-7750 Black and White Copier Logo
69 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
