Question about Apple iPod MA446LL/A MP3 Player
My ipod (video 30gig)
Wont do anything. i disconnected it when it said do not diconnect, while it was "updating" and now the screen is blank and dark and makes beeping buzzing noises outloud. when i connect it, the screen will go white, and itunes and my computer will not recognize it. what can i do?
  • 317 Answers
Re: my ipod (video 30gig)
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Posted on Jan 26, 2008
0 characters
3 Points
Logic board
I just cant hear my songs, it is playing but I am not hearing anything.
Apr 04, 2013 | Apple iPod MA446LL/A MP3 Player
Blank ipod touch srceen wont respond
press the home and sleep button go to this video and see it
Oct 19, 2009 | Apple iPod touch
My ipod wont charge
This is either a bad battery or bad battery connector Hope it just Battery.
Jan 07, 2009 | Apple iPod MA446LL/A MP3 Player
My ipod nano wont do anything
Did you try resetting the iPod? If the battery were dead then when you plugged it in, you'd still see something popping up on the screen. What's possible is that your screen got disconnected from the iPod logic board or otherwise got ruined. When you try turning the iPod on can you hear any noise inside? If you toggle the hold switch does it show the orange light? If you can't hear any noise and it doesn't show the orange light, your iPod's logic board probably died. You can get a new one off eBay and replace it if you're comfortable opening your iPod. Otherwise, you can sell the broken iPod on eBay for a decent amount.
Jan 06, 2008 | Apple iPod MA446LL/A MP3 Player
Apple 5th gen video
Have you tried reseting the iPod (see product manual for how to reset your particular iPod)?
Sep 05, 2007 | Apple iPod 3rd generation MP3 Player
Doesn't reocognize songs and Ipod
Try booting it into disk mode. Do this by clicking on the menu and center buttons at the same time. When you see the apple logo, immediatley hold the centerbutton and play button down at the same time for 10 seconds. The ipod should now say disk mode at the bottom and have a check mark on the screen.
Then connect it to your computer, and format it using your computer. To do that click on my computer, then right click on the drive letter assigned to your ipod (should be like drive I: or H: or similar.. Then scroll down to format and click on format. This should reformat the ipod completely.
Once that is done disconnect your ipod from the computer and reset it again using the center and menu buttons. After it reboots, try reconnecting it to you r computer and see if it is fixed.
Aug 21, 2007 | Apple iPod MA446LL/A MP3 Player
Nano does not work-blank
sounds like it needs to be recharged. plug it into the wall charger or your computer and do not disconnect until it tells you that the charge is complete... this takes time and disconnect it from the computer by dismounting it before disconnecting so not to cause problems
Jul 06, 2007 | Apple iPod nano
Ipod white screen
Reset the iPod:
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
  2. Press and hold the Menu and Select buttons until the Apple logo appears
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Apr 13, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
44 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
