Question about Kenmore Elite 45986 Front Load Washer
Machine stops at Mid Cycle and the Timer Flashes
I am having a problem with the HE4t Frontload washer. It stops at mid cycle with water filled inside and the timer flashes. After I unplug the unit and plug it back in, I press the opition to Drain and Spin but the machine does not spin..... PLEASE help me
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Posted on Jan 25, 2008
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 28, 2016 | Washing Machines
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
Enter your model number to see parts for your washing machine.
Help me find my model number
Water Inlet Valve
Main Control Board
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool 1000 w100 stops after filling with water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 30, 2012 | Creda W100FW Front Load Washer
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
Sep 26, 2012 | Washing Machines
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
Sep 25, 2012 | Washing Machines
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    193 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
