Question about Car Audio & Video
Sony xplode 1 olm amp problems
When i turn my radio up for only a few seconds the subs just stop and the offset light comes on. but when i turn the radio off for a few seconds the subs come back on then it does the same thing. what should i do?????
  • 2 more comments
  • Anonymous Jun 09, 2008
    when i turn the stereo up for a few secs the speakers shut off, an the offset comes on the amp what should i do?
  • ttb23 Oct 08, 2008
    when i turn up the speakers the offset button goes on but then when i take off the ground and take out the rcas and then put the ground back on the offset doesnt go off and then when i hook up the rcas it goes off again ......so ya what should i do
  • samoandood Oct 24, 2008
    overcurrent light overcurrent light overcurrent light! HELP!!! I've tried everything, I have everything hooked up right and i doublechecked my wiring and I still have the overcurrent light come on. WHAT CAN I DO?!
  • slochewin2 Dec 17, 2008
    my fuse blew out and i put a new one in and the offset light vame on and it keeps blowing fuses
    Problem Solver:
  • 10 Answers
Check were you plugged the input to a high or low, giving an amp too much signal will do what you described, certain amps got a limit.
Posted on Feb 02, 2008
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Burnt voice coil??
Sounds to me like your amp is clipping. You can tell by watching the power lights on the amp when your system is cutting out. If so, the most common problem with this, is a bad ground, otherwise, the problem is internal and the amp will need to be repaired or replaced. If your speakers were burnt at all, or defective, they would simply not work anymore. Hope this helps, good luck.
Mar 13, 2010 | Car Audio & Video
When i turn my amp up it goes into over current / offset mode and doesnt come back on until i turn the radio off and turn it back on
ive never liked xplodes it always did that to me..check youre wires make sure they are the correct gauges...if you buy an amp always buy from a dealer and make sure they install it correctly ...
Feb 21, 2010 | Sony XM-2150GSX Car Audio Amplifier
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Music stops 30 seconds into the song
does the music stop? or do the sub(s) kick out. your amp might be to big for the sub rating , try turning down the gain
Jan 19, 2009 | Sony Xplode P5 Turbo Subwoofers Car...
Sony xplode 1000w amp has green light puts out no power to subs
may haveto turn sub on through the stereo itself if rca cables are good.
Jan 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Speakers cut off when bass goes up...
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony Xplod 1000 watt car amp quit working.
Almost all after market amps use 12v at very very low amperage to trigger the amp on. A temporary jumper from the battery plus terminal on the amp AFTER the battery and ground wires are attached should cause the amp to turn on. I would check to see if you have attached your speaker load correctly ESPECIALLY if you are bridging. Most of the blown amps that come into my shop are due to incorrect bridging loads from the speakers. Note that a 4ohm load bridged across both outputs of an amp will deliver a 2ohm load to each of the channels. When you parallel wire two 4ohm speakers together and then attached them to a bridged amp you will be putting a 1 (one) ohm load to each channel of the amp. Please don't make this mistake. It will fry your amp in about a month. Hope this helps. Good luck.
Feb 03, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Car Audio & Video Logo
383 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
