Question about Xerox DocuMate 272 Path-Through Scanner
ADF won't feed the paper. The feeder wheels are heard turning but the paper won't feed.Replaced the "pad" and cleaned the rollers & glass and checked the feed guide and feed sensor.
  • Anonymous Mar 22, 2014
    ADF won't load pages
    President:
  • 2,072 Answers
If those rollers are turning, and not feeding even after cleaning they simply need replaced. they can get so slick that no ammount of cleaning will help.
Thats what is sounds like.
Like trying to drive a car on ice. No traction.
Posted on Jan 25, 2008
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Dec 08, 2014 | Copystar CS-2550 All-In-One Printer
The paper you scan is stuck
There is debris blocking the paper path in the document feeder. This could be a staple or a shard of torn paper blocking the path wedged into a tooth of the diverter arm or a sensor flag. I would suggest that if there is a small wheel or knob closest to you when you raise the document feed lid, put a piece of #28 lbs card-stock into the document feeder guides, turn the wheel/knob to pull the paper/cardstock into the ADF and continue until it either pushes the shard/debris out or stops moving the paper no matter how much you turn the wheel/knob. This will tell you where in the ADF (Automatic Document Feeder) the blockage is located.
Nov 06, 2013 | HP OfficeJet Pro K8600 Printer
The automatic document feeder doesn't grab the paper unles the sheet of paper is pushed. Even then, feeding doesn't work well. Can you help?
Generally, you could clean the document feed rollers with WD-40, or a platen cleaner, but better yet, you should replace the pads and feed roller and I think you could do it yourself with my roller kit:
Roller ***'y,ADF Pick-Up,M1522n/nf/M2727/CM2320mfp
Part no. 5851-3580
Feb 17, 2010 | HP LaserJet 2727NFS All-In-One Printer
Brother printed paper issue
The ADF feed-in rollers need to be cleaned or replaced. Try raising the ADF lid and clean all the feed rollers with a soapy solution and cloth. If the problem persists, the rollers and double-feed prevention pad should be replaced.
Dec 07, 2009 | Brother IntelliFax-2820 Laser Fax
Paper feed only works manual
I think you have a paper jam or some other tiny objects like a paper clip or the like blocking the ADF(Automatic Document Feeder) roller. You should open your ADF and check for anything obstructing the roller. If you see something just pull it off close the ADF and turn on the printer.
Good luck,
Sai.
Dec 02, 2009 | Brother HL-2070N Laser Printer
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper wont feed through on my canon fc224 photocopier
On these fax machines the most component that gets the most usage are the feed rolls.
Even though they are hard to find and hard to reach, using a flashlight one can view the surface of the feed wheels. By inspecting the surface, they may appear to be shinny instead of the normal feed wheel surface tracks.
Either the wheels need to be replaced or cleaning the surface might get a little reliablity, eventually they may need to be replaced.
Some feed wheels have a lower or they might be on the upper part of the drive train, where they have a square rubber pad.
This is especially true with document feeders, the most common part that wears out.
These pads or, arm tips wear out and need to be replaced.
I hope this helps out.
Oct 17, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
May 29, 2009 | HP Officejet Pro L7650 Printer
Ep1083 copier
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Aug 27, 2008 | Minolta EP1083 CS/PRO Copier
Top Paper Feed Won't Work
Like a worn running shoes, the paper feed roller of the Automatic Document Feeder (ADF) have lost it's traction and has to be replaced or cleaned. Paper just slids and doesn't picked up properly without that little push. Professional servicers use a cleaner specifically designed for rubber rollers. However, YOU CAN get extra miles on it by dabbing a Q-tip in warm water and cleaning the paper feed roller on the ADF. Like all eletrical devices, the unit has to be turned off and unplugged before working on it. Take all precationary measures and goodluck.
Nov 29, 2007 | Brother MFC-3240C All-In-One InkJet...
Xerox DocuMate 272 Path-Through Scanner Logo
602 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
