Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Wireringhowto i need to wirer 2 baseboradheaters 1 stat with4 wires 10/24wires need help to make connections
  • 2 more comments
  • sack1 Jan 30, 2008
    i have the same problem, i have a 240 volts fahrenheat electric convector baseboard heater, i would like a diagram of the wiring, with the termastat. plz e/mail me at hardworker662@yahoo.com .
  • Anonymous Apr 26, 2008
    followed directions breaker keeps blowing
  • mdv1 Apr 26, 2008
    where does the main power go,does red go to black on the top and the bottom.
  • kaclark Aug 04, 2008
    We are having the same problem - follow instructions and the breaker blows. Help!! Please.
  • 625 Answers
Look up my profile and send an email there. I will provide you with a point to point diagram.
Posted on Jan 25, 2008
Amana model gmh95070
Don't need the blue wire is common for the ac condsor unit what t-stat is it honeywell 4000 6000 8000 or one of rth models there is many t-stats as far as you saying fan stayes on check the auto / on section of the t-stst main wirers are RH/R-power W-heating Y-coolin G-fan
Mar 14, 2014 | Goodman Heating & Cooling
2 wirers for 2 capacitors 1 wire is blue and 1 is red
You will need to post more information:
Brand name
Model number
Mar 13, 2014 | Heating & Cooling
Rheem Heat Pump Thermostat Replacement (#41-20804-15)
you need a 2 stage heat and cool t-stat hunter t-stat is not 2 stage
Feb 19, 2013 | Heating & Cooling
I have a Honeywell LR1620 Thermostat that I am replacing with a Honeywell RTH230B. I se where all the wires go to on the new thermostat EXCEPT the blue wire that is attached to the "W2" terminal...
If your old t-stat had a W2 terminal with a blue wire connected, and your new t-stat does not have a W2 terminal, then you may have purchased the wrong t-stat. The old is a 2 stage heat where your new is a 1 stage heat. 2 stage heat means the tstat will engage 2 heat elements, then if it continues to get cool inside, the Tatar will engage w2 and the remaining 1 or 2 heat elements. If you want it like it was to begin with, you'll need a 2 stage heat 1 stage cool tstat.
Oct 10, 2017 | Heating & Cooling
CAN YOU PLEASE GIVE ME A LINK THAT HAS A PICTURE OF THE COLOR EACH WIRE REPRESENTS AND HOW IT CORRESPONDS WITH THE CODES. Y1 W/B Y/0 RH RC G
R Red 24 volts coming from equipment to stat
W White First stage heat (could be W1)
W2 Second stage heat
Y Yellow First stage cooling (could be Y1 on your stat)
Y2 Second stage cooling
G Green Blower
C Common (Neutral)
B Reversing valve for heat pump
O Reversing valve for heat pump
If you have singles transformer system. Rc and Rh will be connected.
If you have 2 separate systems. i.e. Boiler heat and Central Air. Boiler Red to Rh and C.A. red to Rc.
Jan 18, 2011 | Hunter Heating & Cooling
HELP!! New install of GMUH75-E3A - Main blower starts immediately on power up/ thermostat turn on. Burner never turns on/ignites. AC power is wired correctly and gas supply is connected. Switch is in the...
You need to find out if the problem is in the T-stat, T-stat wire or in the furnace you can do this in a few easy steps
Step 1- Unwire the low voltage from the furnace. Then turn the power back on and see if the blower comes on if it does then the problem is in the furnace and you will need to troubleshoot the furnace (see bottom of page for troubleshooting furnace) if it does not then proceed to step 2
Step 2- Wire the low voltage back up to the furnace (follow the wiring diagram below). And unwire the T-stat, make sure that no wires are touching each other, then turn the power back on to the furnace, if the blower starts then you have a short in the T-stat wire and you will need to pull a new wire. If it does not then proceed to step 3
Step 3- Turn the power back off at the furnace and wire the T-stat back up (follow the wiring diagram below). Turn the T-stat to auto heat 90 if the heat does not start but the blower just runs then you need to replace the T-stat.
http://www.hvac-for-beginners.com/furnace-troubleshooting.html
wiring diagram
Nov 24, 2010 | Comfort-Aire Heating & Cooling
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
How do i connect the speaker wirers of a stereo car radio to a classic 1976 granada 2 speaker 1 front 1rear mono system with balance cntrol.
well u should send me ur type of ur radio. but if u mean that u know how to connect the wires then all u need to do just trace the wires from ur speakers to the place which u want ur stereo to be connected with speakers
Jun 07, 2009 | Ford Granada Cars & Trucks
Old Gas furnace(heat only)
Yes, it only needs 2 wires to run.
Please rate Fixya solutions
Jan 20, 2009 | Hunter Fan Company 5/1/1 Programmable...
Wiring a thermostat
your red wire will go to the R, RC, or RH terminal on the stat does'nt matter which one ,this is the wire that provides 24 volt from the furnace. the white wire will connect to the W terminal on the stat. If there is a jumper wire that came on the stat going from RC to RH leave it on.
Mar 08, 2008 | Honeywell Electronic Programmable...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
78 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
