Related Tags:
This problem should be removed because:
Problem with Brother Multi-Function Center MFC-440CN All-In-One InkJet Printer
Brother MFC-440CN won't print color
We have had our printer for a year. Recently it has had a few major paper jams. Since then the print quality is poor and it won't print in color. We have run it through the cleaning cycle a few times. Any suggestions? Thanks
Solutions (4)
Best Solution
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
can.t get my re or yellow to print Black and blue are ok
please help
can't get my red or yellow to print black and blue are ok
please help
If you run original ink you have to run the special cleaning mode again. There could be some air within the tubes and/or ph which prevents the good print quality.
If you have used generic ones, this could be because of bad ink quality that has affected the ph!
I have a Brothers MFC6490CW laa i one printer and the black ink will not print I get a blank page please help I have bought 2 cartages still won"t print
Selphy DS700: False paper jam message and poor...
My new DS700 started by having very poor print quality - stains across picture, blotchy ink dots etc.as if ink release is not controlled...
CLJ8550n poor print quality and wrinkled paper
We have a CLJ8550n printer. When we print from the tray used for tabloid size paper it wrinkles the page. Is there something I can do to try...
Poor print quality .... Canon Pixma MP140 ...
Hi there .... I have recently set up this printer and when printing, the color quality is quite faded. I have been printing on just regular...
Paper jams at the same spot, prints half of the...
Paper jams at the same spot, prints half of the document clearly then jams. When I open the back door & shuts it, it continues to print...
Add Your Solution
Brother MFC 440CN will print graphics, pictures,...
I have gone through all the trouble shooting options and even deleted the printer and then added it back. Turned the...
printer dpc 165c ada pesan unable 4f
printer saya brother DPC-165c pada LCD ada pesan unable 4f gimana ya cara menghilangkan pesan tsb.dan printer bisa di...
i can't turn off my printer brother mfc-465cn
Fix-O-Meter
3,816
3,816 people viewed this problem
- 11 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Brother Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
We have never used anything but brother ink.
you have to press the buttons one after another very quick:
MENUE - START BK Copy - 4x ARROW UP
After that you should see all buttons flash and "maintenance" on the display.
Do procedure as mentioned in my first post.
BTW:
Did you normaly disconnect the mfc from power (by help of a power switch or unpluggin it)?
The mfc runs automatic cleaning cycles to prevent bad printing and to keep the print head alive. This consumes some very little ink.
Never unplug machine from power! Do set date and time because machine
needs info about when to start cleaning procedure.
