Question about Goodman GMS90703BXA Heater
1993 goodman status light 4 times blinking
I have 1993 goodman gas furnace. the furnace is blowing with cold air. no flame. the thermostat is running on battery. the status light on goodman is blinking 4 times. seems open limit switch on the panel description. I replaced the air filter. still no heat coming while fan is blowing. your help appreciated in advance
  • 4 more comments
  • atlgeek Jan 25, 2008
    the limit switches (1 main and 1 aux )are attached onto the furnace and I see there are 4 rollout switches ( round and two wire attached and the other side has a switch with pink mark) around the furnace (top, 2 sides and 1 bottom). The filter was dirty and is replaced. is the rollout faulty?
    What would be the correct sequence to reset the system?
    thx
  • Anonymous Mar 11, 2014
    Toyota twincam 4age doesn't idle
    car shuts down while driving may or ay not start have replaced distributor cap, rotory button, wires, and oter pt
    i have just had gearbox, clutch and associated parts replaced on an 02 Peugeot 206. all was fine at first but now battery light has started randomly coming on whilst driving. no problem starting, as yet!.
  • Anonymous Mar 13, 2014
    model DGAA056,furnace, blows the 3 amp fuse, if both of the limit switches are hooked up, but if you unhook one of the switches the blower fan comes on and the light code reads 4 flashes, open limit switch, also made sure both switches where normaly closed.
    Problem Solver:
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
  • 447 Answers
If the code description for four flashes is an open limit switch, than you will need to figure out how many limit switches (they shut the furnace down in case of overheating) your unit has. They look like small discs with 2 wires attached. Look around the burner tubes for the limit. If there is a little red button than you lucked out it is a manual reset kind, if there is no red button than it will have to be replaced. You can try putting the two wires on the switch together just to test. Of course it is very dangerous to leave it bypassed. Also im sure air filter was so dirty that is why overheated??
Posted on Jan 25, 2008
  • joey  shearer
    joey shearer Jan 25, 2008
    I would use a volt-ohm meter to test all for continuity.
    Genius:
  • 1,067 Answers
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
  • 4 more comments
  • nick helpap
    nick helpap Jan 25, 2008
    "4 blinks =open limit
    check main open limit or aux. open limit"
  • nick helpap
    High limit is a normal closed position, and stays that way. Limits open in the event of a filter blockage or a coil blockage.
    High limits are located in the upper portion of the unit, locate it and jump that puppy out and see if she runs from there.
    Limits are cheap,$6.00 boards on the other hand can run up some cash, $120.00 and up depending on your unit.
  • nick helpap
    On - OK
    1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
    2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
    3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
    4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
    6 Blinks - False flame sensed. Check sticking gas valve.
    Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
  • nick helpap
    FYI I had a case not long ago of a 6 flash code, found that the ground wire from the control board was not secure. Must of gotton pulled when they replaced the filter
  • nick helpap
    An open limit means the airflow temperature in the heat exchanger was too high or you had a roll out switch trip due to flame entering the burner area. Check your filters and evap coil and make sure they are clean. It would be a good idea to have the heat exchanger check as well for cracks due to how prone GMP-125's were to cracking with poor airflow.
  • nick helpap
    dont forgetto mark me as fix ya ok
Furnace running but cold air coming out of vent!
There may be a dirty flame sensor, post the model number
Dec 20, 2017 | Goodman Heating & Cooling
Goodman gmp0503 unit has status light blinking slowly all the time. The indoor blower wont even come on when you switch from auto to fan on thermastat. The status light says for one blink to check gas...
Take a jumper wire and jump out the R and W terminals on the furnace. The heat should come on. If it does not, you have a bad board. A steady blink indicates no call for heat. You may have either a broken thermostat wire or a bad thermostat if unit fires when you jump it.
Mar 20, 2011 | Goodman Heating & Cooling
Central heat not working right
You may just have a dirty air filter or your furnace may be flashing an error code that could help you. Look for a small viewing port that looks into the cabinet of the furnace. Look for a blinking light. Count the blinks and then find the wiring diagram pasted to one of the panels. On the diagram it will have a diagnostic chart where you can look up the error code. Read on for some basic info that may help you.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Feb 08, 2010 | Goodman GMS90703BXA Heater
My heater blows cold air. any ideas?
Your unit has a diagnostic light on the circuit board. You need to look thru a small viewing port to see it. Once you count the number of b links, remove the lower panel and look at the wiring diagram for an error code chart. Then read the following to give you some ideas what to do.
Dec 01, 2009 | Goodman GMS90703BXA Heater
Goodman Dependable 92 blowign cold air only - no heat
blowing cold air on this furnace usualy caused by high limit trip, or flame roll out. the first one, (high limit) is from insf. air flow. (blocked filter,bad zone damper?
The second,(flame roll out) caused by bad heat exchanger,blocked vent.ect.
Jan 09, 2009 | Heating & Cooling
Goodman furnace blinked 1 time
Furnace attempted to start but failed after so manay tries. This may help you.
Sequence of operation, Gas Furnace.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light).
This is why we technicians earn the big bucks!
Dec 05, 2008 | Goodman GMS90703BXA Heater
Carrier Furnace wouldn't light, fan was running all the time.
Most furnaces have a photo cell if it gets dirty the photo cell does not see a flame so it trips the reset button on flame failure.
May 13, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
1,095 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
