Question about Philips 55PP9502 55" Rear Projection Television
Phillips picture is very white and color is off a little
Hi. I had the same problem with my Philips RPTV and the fix is extremelly ease. You just need to open the back cover (mine uses torx screws). Inside the tv is very mechanic. You will find the three CRTs and most likely the lenses are dirty. You just need to wipe them off with a soft cloth. Also the CRTs project the image not directly to the screen, but to a big mirror and that mirror will be most likely dirty (like when you open the hot water in front of a mirror). Once you clean the mirror and the crts, your tv will like as the they you got it.
Posted on Mar 23, 2009
HI, I have a White Rodgers model 1F89-211 thermostat. All I did was move it to the opposite side of a wall into another room and now it runs backwards. I heats on cool and cools on heat. Help?
Phillip...
The SECRET is to connect it exactly as it was (before).
The screws on the control are color coded
R,W, Y AND Green... TYPICALLY that MATCHES THE TERMINALS OF THE SAME COLOR inside you heater controller.
Yes ... Red, White... Yellow...
What you need to do is look at the picture you took... or the notes you took BEFORE disconnecting those wires...
ELSE...
Go to where the HEATER CONTROL BOARD IS...
Pull the front cover... Snap a picture for your memoirs...
and write a TRUTH TABLE
AT THE HEATER... TAKE NOTES...!!
RED SCREW = (for example red wire)
Yellow =
Green =
White =
BACK AT THE Thermostat Screws:
RED = (
SAME COLOR WIRE as at the HEATER)
Yellow = (SAME COLOR
WIRE AS THE HEATER)
Green = (
SAME COLOR WIRE AS THE HEATER)
White = (
You should be fine...
Carnac the Magnificent
Dec 07, 2016 | Heating & Cooling
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
I have a Phillips 60PP9202/17F rear projection TV. its getting worn. The overall picture seems to have a slight haze and also seems to have lost the color contrast. yellows and whites are very similar and...
Thats most likely a CRT coolant issue where you will need to remove and replace the coolant in the CRTs ( picture Tunes) Thats a very common problem with Phillips rear projection. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for a 3 CRTs and the CD with instructions.
Jul 22, 2011 | Philips Televison & Video
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips DLP 50 inch has no color great black and white picture
There is no color chip. What it does have is called a motor driven color wheel. The problem is that the color wheel is no longer spinning to produce color. Replace the color wheel and you should be fine.
Dec 31, 2008 | Philips TV Tuner Video Capture PCI Card -...
Phillips magnavox 55" projection
The coolant needs to be changed in the CRTs ( picture tubes) this is a very common problem with all phillips and magnavox rear projections. Changing the coolant will restore the color and brightness and stop the halo effect. You can get the phillips CRT coolant kit at the following link and it includes all the coolant and the step by step instruction CD with pictures. Its actually a fairly easy job. Heres the link its listed under the repair Kit category.
http://servicemanuals.vstore.ca/
Oct 14, 2008 | Televison & Video
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 55PP9502 55" Rear Projection Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
