Question about Canon PIXMA MP130 All-In-One InkJet Printer
Service error 5100 on canon pixma mp130
How can i get rid of this service error i have no resume button on this printer?
  • 7 more comments
  • Anonymous Jan 26, 2008
    Help I put in new ink cartridges and cannot get rid of the error 5100 on canon pixma mp450. I don't have a resume button on this printer. Help!
  • POLET Feb 06, 2008
    I CLEANED ROLLER AND BASE CYlIDER AS DISCRIBED IN MAINTENANCE.WHEN I TRY TO COPY FROM PC OR PHOTOCOPY 5100 APPEARS. [email protected]
  • Anonymous Mar 25, 2008
    I have changed the cartridges, cleaned and still will not print, just comes up error 5100. At one point the display window showed cartridges are jammed. I have no idea what is wrong with it , but if anyone has a solution please advise.
  • Anonymous May 27, 2008
    I have the same problem service error 5100 it all started when I replaced the colour ink tank - saying its jammed!!!
  • alchipal Jun 06, 2008
    service error 5100
  • Anonymous Jun 12, 2008
    Service error 5100 and catridge jammed, trying cleaning, nozzle check etc, error keep appearing
  • Anonymous Jul 04, 2008
    please help me with code 5100
  • jenron14 Aug 26, 2008
    doent print
  • TJ_JACKSON00 Apr 30, 2009
    I have service error 5100 and canont print doccument HELP
When this happened to me, I beat my head against the wall until I finally figured out that the waste ink absorber on the right side (spongy looking thing), was overflowing, and clogging the nozzles. I took a piece of paper towel and absorbed some of the ink. Make sure to wipe the colored ink absorber as well.
Neal Moilanen
AAA Virtual Assistants
http://www.aaava.net
Posted on Jan 03, 2009
I wanted people to know that you MAY get this error when all you need is a new ink cartridge.
Such was the case with mine.
I got the error, read all the solutions here and other places and they either required opening up my printer and fiddling with its innards, which I was not going to do, or they made it sound as if it was dead.
I tried cleaning that plastic ribbon, and I unplugged it and restarted it several times, and these things did seem to help get it responding again. Before it would do NOTHING, just give me the error message.
After 4 -5 starts and restarts, it began to at least TRY To print but there was no ink showing up, just a faint bit of ink you could barely read at the bottom of the page.
At that point I said "Hmmm, maybe it just needs a new cartridge. Maybe the cartridge is not fitting right and that is the problem."
"But do I want to spend $30 on new cartridges only to find out that is not the problem?" The answer was no.
As a compromise I went out and bought JUST the black ink cartridge.
When I tried to install it, it did not seem to fit. Almost as if it was the wrong cartridge. Weird. I looked in there and could see nothing obstructing it, so I kept trying to get the new cartridge to fit. Finally it did snap into place, and....
That solved my problem! (at least for now) I will add to this if this turns out not to be a permanent solution. Otherwise you can assume it did fix the problem permanently.
I am not saying that Error 5100 is always a sign of just needing a new cartridge. But it might be worth a try to buy a black ink cartridge and try it, if all else fails. Remember, that first you have to at least get the printer to act like it will print. For me, starting and restarting it (also unplugging both the a.c. and the USB) and cleaning that plastic ribbon inside got it acting like it wanted to print again. Then the new cartridge finished the job.
Posted on Oct 18, 2008
Ok, I have had this code twice. First time I unplugged both power and computer connection for over 30 seconds and the error message cleared upon reconnection. Months later it happened again.
The second time was when I was trying to print with the colour when it was saying only black needed replacing. It turned out that colour had an incorrect reading and also needed replacing. So maybe try replacing ink cartridge, or shaking cartridge.
Posted on Jun 07, 2008
I had the same problem. For me, it wasn't required to switch ink tanks. I just had to take out the USB & power cables, wait for a few minutes, put them back in and it started working again, fortunately.
Posted on Feb 09, 2009
Printer service error 5100
Posted on Jul 01, 2008
I have a MX700 and it has error code 5100  help
Posted on Jan 25, 2008
5100
Posted on Jun 29, 2008
Get a new printer?
Posted on May 20, 2008
6ya staff
SOURCE:
I have a Canon Pixma MP 130/110 Printer. Machine is not printing. Have been through all the recommended cleaning/ maintenance procedures several times and fitted new ink cartridges all to no avail. Message...
Pixma IP3000
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Mar 06, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Please send me the solution of Service error 5100
5100 is service error. just follow this steps to fix this,
1. Hold RESUME then press & hold POWER
2. Release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Dec 17, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma mp130 service error 5100 - won't print
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100 - paper does not feed properly, and now printer is not printing at all
1) service mod turn off printer unplug power cable and press resume and plug cable and push the turn on button and press resume 2times and relase buttons and wait until the light is green and press resume for 4 times and press turn button
Aug 11, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Mar 23, 2010 | Office Equipment & Supplies
My Canon pixma Mp 450 printer is showing error code 5100 what is wrong with it?
it is service error you can fix this by doing this steps
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 19, 2010 | Canon Pixma iP4500 InkJet Printer
Service error 5100 on canon prixma mp198
Service Error 5100
Cause : Movement of the Print Head Holder is blocked.
Action "Clear the paper jam or foreign object that is preventing the Print Hed Holder from moving, cancel printing from your computer, then turn off the machine and turn it back on again.
Hope this helps.
Thanks
Have a good day.
Dec 06, 2009 | Canon PIXMA MP130 All-In-One InkJet...
It shows an error massage "service error 5100"
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Oct 25, 2009 | Canon PIXMA iP1300 Printer
Canon Pixma MP130 Error message:- cartridge jammed service error 5100 How do I rectify this problem?
I HAVE THE SAME PROBLEM- CARTRIDGE JAMMED-. :o( I HATE PIXMA MP130, cant seen to make it work, last resort: throw it against the wall! GGRRRR! if you find a solution please post.
May 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
7,284 people viewed this question
Clive
Clive
old marine
old marine
Ekse
