Question about Whirlpool GEW9250 Electric Dryer
Dryer won't start, Simpson Eziloader 4kg
We suspect the timer has been effected, the kids may of turned the timer dial anti-clockwise. The dryer won't intiate (turn on). Appreciate your feedback. [email protected]
  • Anonymous Mar 16, 2014
    It dosnt tumble i theres nothing wrong with belt what can it be than
  • 55 Answers
Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
Posted on Jan 25, 2008
  • 283 Answers
On dryers with the old mechanical timers you can turn the knob in either direction without harming the mechanism. On either type, even electronically controlled models with a problem like you described, there are a lot of possibilities. After confirming you have power to the appliance check the thermal safety fuse located on the heater housing.
6ya staff
SOURCE:
We have put a new belt and bearing on my 4kg Simpson eziloader dryer and spring is in place it works for a while and then the belt comes off again what could the problem be
I would check the pulley on the motor, and the belt tensioner that the belt winds through. My initial thought is that when installing the belt onto the tensioner it may have been bent. GOOD LUCK FRIEND.
Nov 16, 2014 | Dryers
Hi I have a Simpson 4kg eziloader dryer that keeps tripping the power mains . Would this be the timer ?
The heating element uses the most power. Was the home wired by a licensed election ( the dryer plug)? if it was it should have #8 or #10 wire depending on the load. the breaker is sized to the wire (so don't change it). you may have a clogged vent pipe. this will reduce air flow and make the dryer work harder possibly tripping the breaker. You should probably start by making sure you vent is clear and free from debris, debris in the vent could cause a fire.
Sep 10, 2014 | Dryers
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
If the faint noise is the motor running, the belt is broken.
Jan 03, 2014 | Dryers
My simpson 4kg dryer drum not turning,still heats,making a wuring sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2011 | Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
Hello My simpson Eziloader Dryer will not spin I replaced the drum belt but still not fixed, if I turn it manually and close the door really quicly it will start turning but then stops soon after. Please...
need the cap replacing,........... should ba a silver can shaped cap. sited next to the motor
. it will have 2 or 4 wires connected at the top......................
cheers
Mar 24, 2011 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
How to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Aug 29, 2009 | Dryers
Dryer will not spin
are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
1,846 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
