Question about Refrigerators
HOW TO ADJUST WATER LEVEL IN ICE MAKING TRAY
I WOULD LIKE TO KNOW HOW TO ADJUST THE WATER LEVEL IN THE ICEMAKING TRAY OF A RS21DCNS. I NEED TO INCREASE THE WATER LEVEL AS AS THE CUBES ARE TOO SMALL. THE WATER PRESSURE AND WATER FILTER HAVE BEEN CHECKED AND ARE OK.
  • Anonymous Mar 17, 2014
    The model is LMX21986ST
  • 63 Answers
Your water pressure is too low. If you live in an area with low water pressure you would have to get a booster pump for you frig. Otherwise you can check the supply line and make sure it has no kinks in it. according to the manufacturer the small ice cubes will not effect the performance of your frig
Posted on Jan 28, 2008
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
My ice freezes as a block when dispensed into ice tray
There are water level adjustment screws behind the plastic cover of the ice maker to adjust the water level when it refills after dumping a tray of ice. When there is to high of a water level it spills over onto the cubes freezing them into a big block. Try to adjust the level of water. There is a arrow which tells you which way to turn the screw to get a smaller fill fixing the problem.
May 04, 2014 | Refrigerators
Hi have a rs21dcns samsung can any one tell me how long it take to produce ice cubes fo the first time as the manual is not clear about this, and is there any tips i should know thanks
The first time should be on the average of 20-25 minutes. If your samsung is taking longer than 30 minutes, it indicates there is a problem. Fiscally look in the ice tray and verify the water is in there. If not, check and make sure the water line to the unit is connected and the water is supplied to the line. If the water is in the ice tray, then make sure your fill lever is in the down position. This lever is designed to stop making ice when the ice bin is full. If the lever is up, it will stop making ice.
Jun 26, 2011 | Samsung RS2630SH Side by Side Refrigerator
Arctica ice maker won't work without help
The solenold valve would not shut off completely & was leaking water on the paddle that the controls the icemaking. We replaced the solenold water valve & we now have ice!!!!! Good luck!
Feb 20, 2009 | GE Profile¿ Arctica® Energy...
Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Oct 04, 2008 | Refrigerators
Icemaker
did you find out how to fix it ? please let me know
Jul 06, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
Sep 16, 2007 | Samsung RS2534 Side by Side Refrigerator
Rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Jun 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
321 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
