Question about Samsung HLS6186 Television
Shuts off by its self
Recently, my TV has been shutting off by its self every few minutes, can you help me? thanks.
  • lionelat Jan 25, 2008
    I believe its the fan,were can I buy one.
    Checked fan, its working, when tv shuts off, two lights on front of tv flash, standby and lamp.But picture is fine, could it still be the lamp?
    Genius:
  • 1,067 Answers
Maby bad power cheak plugs let it cool down maby fan went out or bulb is messing up or hot in there dusty change plug 1st try these how old is the bulb in it do u have faded picture
Posted on Jan 24, 2008
  • 5 more comments
  • Anonymous Jan 24, 2008
    in good power strip grounded well light is on strip saying so very impornt touchy power on these tvs most american homes have bad power 90%
    thers no auto timer on in it also is there
    Check if the ventilation hole on the rear of the set is blocked, because
    if the inner temperature is too high, the power will shut off.
    • It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately.
    • The TV has a fan to keep the inside lamp from overheating. You’ll occasionally hear it working.
    Standby state.
    The picture will automatically appear in about 15 seconds.
    Auto Timer ON/OFF has been set and the set will automatically be
    turned on in about 25 seconds.
    A cooling fan inside the set is not operating normally.
    Lamp cover on the rear of the set is not properly shut.
    Lamp may be defective. Please contact a certified technician.
    these are the isse u can have can u count or see the circle on the tv and tell me if left or right side is lit up in red or the whole circle were u turn it on at >
    http://media.onecall.com/Image_Products/...
    at bottem shows u how to cheak bulb ok
  • Anonymous Jan 25, 2008
    might not be the lamp them if u still see picture thats looks good could be the engine behind it
6ya staff
SOURCE:
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
Vizio M470NV just purchased, while watching TV it turns off with the Vizio light blinking between orange and white. Can not turn back on !! I have to just wait for about a minute then tv turns back on by...
I have the same issue on my Vizio M470NV. I called Vizio and they told me it is a self diagnostic test that is shutting down the TV automatically to protect it. They said they are working on fixing the issue with a firmware update that will be pushed out automatically if you are connected to the internet. No ETA given on when that would happen. I called them on the 3/14/11 and my TV is still shutting down randomly.
Mar 18, 2011 | Televison & Video
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
I have a toshiba tv that turn it self off after few minutes
Is the tv getting too hot and shutting off? Vacuuming will help get the dust out of the fan but inside the actual tv there may still be dust blocking cooling.
Jun 20, 2009 | Toshiba 32A43 32" TV
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Tv shuts off temp light blinking
There is a fan in the back that should be running. Make sure that tha pathway is clear and that the fan is turning. There are temperature sensors inside that will shutdown the set if it gets too hot. Since this was recently repaired, I would call the repair shop. Most have at least 90 day guarantees. Since you did not have this problem before, they may have missed a connection.
Keep us posted.
Dan
Jun 09, 2008 | Televison & Video
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
Samsung HLS6186 Television Logo
194 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
