Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
Sony kf-50XBR800 tv turns itself on and off
My sony kf-50XBR800 tv turns itself on and off continuously. Put it on, stays for 30-60 sec, then no picture, audio stays on 1-2 seconds then totally off. The red light blinks 34 times, then comes back on and the cycle repeats until I either unplug it, or manually turn off. I've been searching the net, maybe the lamp, but lamp light doesn't light. Heard about thermal fuse issues. The set was purchased in 2003, never replaced the lamp. Any thoughts?? Is this something someone like myself can fix, at my apprentice type level?
I have this same problem. Please help. just happened Jan24/08 today
  • 6 more comments
  • Rod510 Feb 07, 2008
    have the same problem, also when turning the tv off the standby light flashes 5 times pauses and does it again. I have the kf60xbr800 bought in 2003
  • holjencin Feb 19, 2008
    I have the same problem....Does anyone know a fix?
  • Anonymous Mar 01, 2008
    I have the same exact problem.. Any idea how to fix it?
  • ohaeg Mar 08, 2008
    My KF60XBR800 was working fine for 5 years and just started doing the extact same thing last night. Driving me nuts! Research on the web shows it's either 1) replace the lamp or 2) replace the power supply block for the lamp or 3) replace the driver/engine for the lamp. 1 and 2 are affordable DIY fixes, 3 means buying a new TV. Anyone out there have suggestions for us?
  • ChiCowboy May 20, 2008
    Carlos:
    I have the identical problem with my Sony KF-50XBR800. Did you ever find a solution.
    Thank You
    George
    Gdatro@anet.com
  • hotfoot1 Jul 20, 2008
    My Grand Wega is having the same problem. It first started after I moved the set to paint the room. It did this for several hours and resolved itself. A couple of weeks later it did the same thing and resolved itself after I let the TV run for several hours. Now it just does it constantly. Before I request a technician, I'd love to hear from others with the same problem. There seem to be a lot of them out there.
  • DuncansDad Jul 28, 2008
    Exactly the same problem same model (also bought ours in 2003) - good picture for the brief time before it shuts off again.
  • Anonymous Aug 09, 2008
    I AM HAVING THE EXACT SAME PROBLEM!
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
Posted on Mar 14, 2008
Tv won't turn on.
It sounds that the main board if faulty. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy.
Apr 21, 2013 | Sony KF-50XBR800
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
I have a sony LCD projection TV Model # KF-50XBR800 and when I go and turn it on my standby button flashes red and then picture comes on for about 10 seconds then it shuts itself off. Can you tell me what...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 28, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
When I turn my Sony Grand Wega Kf-50XBR800 on,
This is symptom of weak lamp in TV, please replace lamp in TV and I would suggest to buy Sony original lamp for TV safety.
Lamp replacement procedure is written in user manual in details, click Sony Support if you want to download user manual copy.
Thanks.
Oct 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony grand wega started turning on and off continuously
codes consist of N blinks, a pause and N blinks again,valid error codes are 3, 4, 5, 6 & 9 blinks.
Jan 23, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony tv will not stay on
unplug the unit for a couple of minute and plug it back in...if it still wont stay on get a repairman
Jan 23, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
2,194 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
