12.7 GB Quantum Bigfoot
I'd like to use old drive in newer computer as a storage drive - how do I set the jumper settings on a older drive like the 12.7 GB I have that I need files off of
  • La linda Aug 14, 2008
    HAVE A SEAGATE HDD AS MASTER. WANT TO USE OLDER QUANTUM LCT 15 7.5 GB (QML07500LC-A) FOR STORAGE BUT NOT SURE HOW TO SETUP JUMPER SETTINGS TO SECONDARY. DON'T UNDERSTAND PICTURE ON HDD. IT HAS FIVE ROWS WITH THREE BOXES BELOW EACH ROW. STARTING FROM LEFT IS BLANK THE NEXT ROW FRO LEFT READS PK THEN CS AFTER THAT DS AND ON THE END RIGHT THE LAST ROW READS KEY. PLEASE HELP
Assuming your drive is not a SCCI set the master to master and set this drive to slave....normally those settings are on the drive itself.
Fairly simple if you have a pin jumper, a big magnifying glass and small fingers....tweezers work best. Hope it helps...Tango
Posted on Jan 25, 2008
How do you set the jumpers the Maxtor Quantum Fireball Plus AS 20.5 GB hard drive
Jumper settings for Seagate and Maxtor IDE (ATA) harddrives,
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=196299&NewLang=en
Follow the chart examples under the second heading down >
Maxtor (and Quantum) drives follow the jumper configuration noted below.
If I may also add;
1) http://www.youtube.com/watch?v=Ds1-JmbhGRM
2) http://www.youtube.com/watch?v=WwbboeMO7b8&feature=channel
Nov 10, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
When installing a Maxtor Quantum Fireball Plus AS 20.5-GB hard drive as a second drive on a PC. You want the drive to be the slave drive, and you know what that you must change the current jumper settings....
DS=drive select meaning selected drive by the bios CS=Cable select meaning if you hook it to the second plug so set the jumper to CS and hook drive to the second cable if its is ide drive which that is what it sounds like the drive is!!
Jul 21, 2017 | Quantum Fireball Plus AS (QMP20000AS-A)...
Jumper go`s in what line.if power out let it on my right handside
moz-screenshot.jpgHere is a picture I found that shows the jumper settings for:
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
http://www.tacktech.com/images/articles/379/mxo_ata_jumpers_2.png
Apr 26, 2009 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Need to know the slave jumper for the quantum atlas iv hd
If the drive you're referring to is the SCSI model, it doesn't have a "slave" option, but can be set to various SCSI ID's.
Click this link to get the skinny on all your jumper options:
http://support.dell.com/support/edocs/storage/6848p/Jumpers.htm
If you are using it on an older MAC it should work fine set to ID 1, if you want to use it on a PC check first if the PC even has a SCSI connector(rare for PC's of the same age as that drive as they primarily used IDE). The cables look almost identical but are in no way compatible
Hope this helps FixYa
Chris
Armor-IT
Apr 25, 2009 | Quantum Atlas IV (QM309100KN-SCA) 9.1 GB...
Quantum Fireball Plus 10.1 GB
Look halfway down the page for Quantum Fireball LM.....
http://www.tacktech.com/display.cfm?ttid=379
You will find the jumper settings there.
Nov 25, 2008 | Quantum Fireball Plus LM 10.2 GB ATA-66...
Old maxtor harddrive
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Aug 30, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Having trouble using it as a solo harddrive in newer computer
When Windows (XP?) was installed in the Quantum Fireball LCT1520 of the old Compaq Presario, the OS was married to the hardware specifically the motherboard/chipset. When it was removed and transplanted to the newer PC, the OS would be looking for the old hardware settings/configuration and since the new PC has a different motherboard and therefore cannot find the old hardware, it would loop/reboot continuously and/or BSODs.
One method of getting the old HD to work in the new PC is to do a clean/new install of the OS.
If for some reason you prefer to use the old OS in the old HD with its settings/configuration, you can try to do a repair/re-install. The procedure is similar to installing a clean/new OS except that you should opt for the 2nd repair choice (not the R or first repair option). This should retain most if not all of your old applications/settings while installing new Windows files.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Quantum fireball 40 not recognised as master
goto the quantum site and verify the jumper setting on the drive first
if correct then.. check your sata cable is good...
check the bios to boot options so the quantum is set to boot...
under boot options .. hard drives.. sort the drive to be the first to boot
Jan 04, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Computers & Internet Logo
517 people viewed this question
Alun Cox
David Payne
David Payne
