Question about Brother MFC 8500 All-In-One Laser Printer
Fax how can i fax the same paper to a big list of faxes
    Novelist:
  • 171 Answers
Do not use a fax machine. It can only fax to one location. Instead, use a computer with a fax modem and a software tool such as WinFax to do your mass-faxing.
http://en.wikipedia.org/wiki/WinFax
Posted on Jan 25, 2008
Tengo un telefono fax panasonic kxft67 cuando trato de hacer una copia la hoja sale en blanco y tambien cuando me llega un fax su manual dice que es impresion termica que puedo hacer
Thermal fax printers need special thermal paper, and it has to be installed in the proper way, since only one side will print.
Impresoras de fax termicas necesitan papel termico especial, y tiene que ser instalado en la forma correcta, ya que se imprimira un solo lado.
(not sure if Google translated that correctly!)
Dec 17, 2013 | Office Equipment & Supplies
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Which side goes up with Canon fax - L220? Thanks
Get a piece of paper, and put a different BIG mark on each side of the paper, big and bold, then run it through, and see which "Side" comes out, and that's your answer. Just press "Copy" to see. Or you could even send a Fax to yourself, and see. Also to help, your manual is below, that too will show you.
wp.no-ip.biz/download/kezikonyv//fax-l295_Users-Guide_ENG.pdf
Jun 06, 2010 | Canon L220 Plain Paper Laser Fax
Big black line on paper
clean the scanner, lift the auto doc feeder and underneath is a scanner, look to see if there is white out or some other obstruction and clean with a rag soaked with alcohol
May 21, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Is there a cleaning kit for the 2060P? New rollers perhaps,,, my paper jams all the time when feeding a multi page fax
Open the adf where u put in the faxes and u will see a big black roller!Try cleaning it with a damp cloth and see!Good Luck!
Apr 06, 2010 | Canon LaserClass 2060P Plain Paper Fax
Retrieval of faxes in memory
Press the stop key and it will resume printing
Apr 07, 2009 | Canon FAXPHONE L80 Laser
Panasonic kx-f100 fax prints and sends a page on 2 pages- too big
it sounds like one of your rollers is not making contact with the paper. either the roller is dirty or you need a new one
Dec 08, 2008 | Panasonic KX-FP81 Plain Paper Fax
Says load paper recv'd in memory
I had same problem. I put in a big bunch of paper and then took out about half of it and it suddenly worked. Also try opening the lid and then closing.
Jun 17, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canceling a print job?
Remove paper....unplug power....hold down 3 and 6 and plug in.
Mar 20, 2008 | HP 920 Plain Paper Fax
Printing problem
Before we can diagnose the problem, we need a little more info.  Do the internal prints (TX/RX report) also print the line, or only copies?
Oct 16, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother MFC 8500 All-In-One Laser Printer Logo
69 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
