Unit won't power up completely
When I turn the unit on, you can hear a click (which is normal) and the power light comes on, but the display does not come on and none of the buttons do anything. If I hit the power button again, it clicks again as normal and the power light goes off.
Is the unit worth repairing or is it time to retire it?
  • tlaporte Jan 28, 2008
    Thank you for the input. I found the fuse on the transformer circuit board blown. I replaced it and the unit came on okay, but it always goes into the protect mode even with nothing hooked up to it and regardless of where the volume control is set. Also, one of the heat sinks (there are 3 unfinned heat sinks side by side) on the main circuit board gets really hot quickly. I'm sure that is what caused the fuse to blow, but I don't know if its worth trying to fix.
    Tom
  • simmering Jul 17, 2008
    I have the same "Protected" problem but it's sporadic.
The clicks you hear are the relay that completes the circuit for 110V AC to the main power transformer. Mine had the same problem and here's how I've gotten it to work. A lightning strike near our house caused it to fail, and I traced it to the power transformer relay activation circuit. The tuner and amp were fine. I found a bad transistor in the relay circuit, but didn't have a replacement on hand, so I soldered a jumper wire across the relay switch connections on the power transformer circuit board. This connects the 110V AC directly to the power transformer. DC Power to the amp and tuner circuits will still be controlled by the power switch, but the transformer will be supplying all the AC voltages to the main board. If there is a real problem with the circuits that load the transformer or the transformer itself, then the fuse will blow. If the fuse doesn't blow then I suspect the problem is just in the power sequencing circuit itself, that is not needed for operation other than to make the unit "Energy Star Compliant". A lot of electronic items have a transformer that is not switched, and only fused, so that the supplies are available at all times.
Posted on Jan 27, 2008
When I power my Denon AVR-3311ci on, it only comes on for a second then shuts off completely. No blinking red light and nothing on the display. I can hear a relay on the power board clicking. Any ideas?...
There's an electrical problem! The unit shuts off to protect itself. the relay sound is normal and is part of the power supply - good quality amps have them. I suggest taking it to your local repair shop.
Feb 17, 2015 | Denon AVR-3313CI
I have an electronic ignition furnace that won't spark. The blower turns on after about 30 seconds from hearing the ignition clicking but no spark. I noticed when I completed the lighting proced
On that unit the induced draft motor must close the pressure switch, and all safeties are proven closed, then that signal is powered to the ignition control board. Then the board sends a spark. Lots of times all that happens and the electrode that makes the spark needs cleaning, or the ground for that electrode needs to be cleaned/tightened. Takes some process of elimination for that one.
Oct 29, 2017 | Heating & Cooling
My burners won`t click to light
What is the complete model number of the unit?
Dec 15, 2012 | GE Profile 30" Slide-In Gas Range -...
Model khm9qwh5 won't start
This particular model has some sort of internal electronics that require a charge before the unit will function. As a result, when allowed to sit in the cabinet for a long period of time it will simply not turn on. Instead, all you will hear is a "click" noise when you try to power it on. When you get the dreaded "click" noise leave plugged in for several hours and try again.
Nov 05, 2012 | KitchenAid Food Mixers
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
521 people viewed this question
 Grubhead
Grubhead
