Question about Dishwashers
Dishwasher Door Gasket
My new dishwasher door gasket that i installed seems to be to thick and the door wont close now because its too tight.
What can i do about this? Its the right gasket for the dishwasher and i fitted it all the way inside the groove.
  • dish2008 Jan 25, 2008
    Thanks for the advice..... worked like a charm. I just heated it enough, so that it just felt a little warm, closed the door shut overnight and now it shuts easily all the time.
  • 23 Answers
A new gasket will usually seem too tight, as long as it's the proper gasket and you are sure it is properly in place, this may help. Using a hair dryer, carefully warm the gasket up, don't get it too hot that it deforms. Then close the dishwasher door making sure it latches. Run it through a cycle and use the heated dry option. Leave it closed overnite. This should help, although it may seem a little tough to close for the next few times you run it. It will get better with use.
Posted on Jan 24, 2008
I replaced door gasket on kitchenaid dishwasher and now door won't stay closed.
Hope your replaced gasket is identical with the old one! ie dimensions, especially thickness
If so try aligning gasket uniformly over the machine body.
May 20, 2010 | KitchenAid KUDR01TJ Dishwasher
Dishwasher door leaks
If the dishwasher is built-in check to make sure the door is closing all the way and not hanging up on the side cabinet near top of door. If the door is closing properly then inspect the door gasket for cracks, tears, areas that the seal needs seated back in slots, and any debris. If it is damaged in any way a new door gasket seal needs to be installed. www.selectparts.com should have the seal you need at a great price.
May 02, 2010 | Dishwashers
Leaky dishwasher
Check to see from where your dishwasher is leaking. First, wipe off all the area around and below the dishwasher and then check for the source of the leak. If the leak is near the door, give the gasket a look. If the gasket is loose or worn out, you may have to replace it.
If the gasket is fine, you may want to check the latch. A loose latch may be the cause of the leak. Unscrew the latch, and then screw it back in again tightly.
Check all the hoses inside the dishwasher. Ensure that they are not punctured. Also make a thorough check of all the screws inside the dishwasher, and tighten any loose screws yourself
Check beneath the door. If the leak is from under the door, the tube of your dishwasher may have been damaged. You may have to order a new door from the manufacturer and replace it.
Feb 26, 2010 | Dishwashers
MOISTURE AND HEAT ESCAPE FROM DOOR SIDES CAUSING PROBLEMS WITH ADJOINING CABINET DOORS. WHAT IS CAUSING THE CONDENSATION / MOISYURE LEAK?
Unfortunately, dishwasher generate a lot of heat and water vapor. Some manufactures are now including a pressure sensitive mylar / aluminum strip to be attached above the door under the counter to prevent water vapor and or heat damage to wood or composition wood counter tops. However if water vapor is seeping out from the side of the door and causing damage to the adjacent cabinets woodwaork, the dishwasher door gasket may be faulty. Since this might be the problem, it would appear that your dishwasher is used a lot or getting old. New gasket is about $20. If the door closes and there appears to be a lot of play in the closed door,the latch may be in need of adjusting if possible. That is, even thought closed and operational, the seal is not tight and the dishwasher is running without having a tight seal on the sides. If you have a stone counter top, any water vapor / heat escaping from the top would not be apparent since stone is not damaged by the heat or water vapor, but the adjacent wood cabinets are.
Jan 15, 2010 | Frigidaire Dishwashers
The top draw has a small leak in the back. Its about 5 years old. How do I pressure the lines to find the leak?
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks
Rylee
Hi
Thanks
Rylee
Nov 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Jul 11, 2009 | GE Dishwashers
DISH WASHER, STILL HAS A LEAK FROM THE DOOR.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Servicing the Door Latch
The latch on a dishwasher door is opened and closed repeatedly, and this hard use can lead to mechanical problems. The latch may be loose, or it may have slipped out of position, throwing the alignment off and preventing the door from closing properly. When this happens, the latch does not engage properly, and the dishwasher will not start.
In many cases, you may be able to solve the problem by adjusting the position of the latch. Move the latch slightly by loosening the screws that hold it. Slide the latch with your fingers or pliers; the screw slots are made especially for this purpose. Close and open the door to see whether the latch is properly aligned. Tighten the screws to hold it in the correct position.
After repositioning the latch, check to see if it's working properly. Close and latch the door and turn the control knob to the ON position. If the dishwasher doesn't start, the latch is faulty. Replace it with a new latch, connecting it the same way the old one was connected. You may have to move the new latch back and forth several times before it works properly.
PLEASE mark this answer as a fixya! thanks
Dec 26, 2008 | Samsung Digimax A503 Digital Camera
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Frigidaire dishwasher bottom door gasket replacement
thank you so much for this information it was a god send
Oct 07, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
240 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
