Question about Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800
Error Message: Pls open cover
The problem: The cover is already closed. If I open the cover and then close it completely the same message comes out. So I'm not receiving my faxes.
  • Anonymous Jun 10, 2008
    THE PROBLEM; IS THE SAME PLS OPEN COVER AND THERE IS NO PAPER ANYWHERE...I PUT IN A NEW TONER CART. ALSO. WHAT ELSE CAN I DO? NOT RECEIVING ANY FAXES...DD
  • Anonymous Jun 27, 2008
    pls cover open
Likely needs new DR250 drum unit.  Currently going for around $100.
Posted on Feb 04, 2009
    Scholar:
  • 78 Answers
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Posted on Jan 25, 2008
Error message "close back cover"
1. Maybe a Paper Jam below the drum
2. A lever on the inner back cover is missplaced
Mar 16, 2015 | Brother IntelliFax-2820 Laser Fax
Intellifax 4100e ..not receieve fax
Look at the front door that you open when you change the toner/drum. You will see that it has not closed properly at one end. Give it a gentle whack and the error should go. Very common problem as the catches can be stiff.
Mar 11, 2014 | Brother Intellifax 4100 Business Class...
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
There is an error code #77 that tell me to unplug the fax machine and call brother
Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the top cover is
opened and closed, or the machine exits from the sleep mode.
Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Oct 27, 2010 | Brother IntelliFAX 2800 Laser Fax
Machine has a error code of 77 and said to phone Brother - what does this mean?
Apr 28, 2010 | Brother IntelliFAX 2800 Laser Fax
Brother intellifax 2800. Replaced drum, display
Open the drum cover and hold down CLEAR for 10 seconds.
Jan 28, 2010 | Office Equipment & Supplies
My Brother 560 says top cover open when the cover appears closed.
Make sure the covers are completely closed. Open each section an close it making sure it closes with a click. Also check for covers under other covers.
Hope this is of some help.
ED
May 09, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Brother fax 560
check the cover sensor arm if it still in place or check the cover hinge or lock if its still good.
Jun 30, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Jan 07, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
827 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
