Question about Maxent MX-26X3 Television
Loss of Color
Have two basic colors blue and yellow or green as the combination all other colors are grey, just happened when I turned on tv last night. Have check the color contrast etc, all at manufacturers pre set
  • Anonymous Apr 15, 2009
    I turned my tv on and there is no red. All other colors appear to be off because of this. The Red Sox are wearing a dark almost black color and the field looks terrible.
Have two basic colors blue and yellow or green as the combination all other colors are grey. What are my options...The Boston Celtics Colors are Grey. All others colors are good.
Posted on Jun 16, 2008
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Have a Sanyo big screen tv but need need to adjust the color, to yellow!
Need to know if older set with picture tubes---turn color off--if yellow screen you have a loss of blue of some sort--red and green will give you a yellow screen. If set has the 3 picture tubes look inside in the lens to see if all 3 have a image---little or no blue means a problem there.
Oct 15, 2012 | Sanyo Televison & Video
Who decided that black should be the last color for belt grading in martial arts?
Each belt color signifies a level of skill and technique learned throughout training. If each belt color is combined together (yellow, orange, green, purple, blue, brown and red) they would eventually produce black - thus determining why black is the final color level.
Sep 02, 2012 | Adidas Martial Arts
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
Ive got the red power wire hook up and the yellow 12v hot all the time but dont now what color the ground wire is or the speekers are
Your ground wire is going to be black. Your normal wire colors are violet and violet/black, green and green/black, white and white/black, last but not least you have grey and grey/black. Those are your speaker wires. Solid blue is usually to power your antenna, and blue/white is for your amp turn on lead. Those two wires are approximately .5mV of power, and you can actually use either one to turn an amp on. Speakers: normally your solid color is positive, while the black stripe is your negative. As for which one goes to which speaker, left front is white, right front is gray, left rear is green, and right rear is violet. Hope this helps.
May 17, 2010 | Car Audio & Video
Need the radio wiring diagram for a 95 camaro
yellow is power . red is ignition or acc. black is ground. front speakers : left positive tan, left - grey , right - light green , right + dark green , rear speaker : left - yellow , left + brown , right - light blue , right + dark blue . this is for the fatory wire color code if u need the actual wire color code for cd player it is . white is front left , grey is front right , green is rear left , purple is rear right. solid colors are positive and wires with the colors listed with black stripes is for the negative
Mar 08, 2010 | 1995 Chevrolet Camaro
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Loss of color - all green
yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Sep 28, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Yellow image
Could be many things that cause a loss of blue, CRT, Video output IC, driver transistors, etc..
Jan 30, 2007 | Toshiba 27AF41 27" TV
Televison & Video Logo
1,230 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
