Question about Linksys Wireless-G WRT54G Router
No Installation CD
Hi! I'm fairly new to wireless so bear with me please. We have HS internet on a desktop. A friend gave us a linksys wirelessG WRT54g. Is it absolutely necessary to have an installation CD or can it be connected relatively easy without?
    Habit-Forming:
  • 59 Answers
No it's not needed, the main things you need to know is the IP address that the router is set to and it's login details which hopefully your friend can give you. (default IP: 192.168.1.1, default login and password: admin and admin)
After that, as long as your HS Internet modem has an ethernet port you would connect that to the Linksys and your PC's to the routers LAN ports. You can then also login to the router and setup the wireless part if you have any wireless devices to use with it.
Posted on Jan 24, 2008
    President:
  • 2,351 Answers
It is recommended to install the software before connecting cables. You will need to look on the underside of the wireless router for the model number & version No# to get the correct software. You state it is a WRT54G. Go to this site http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
Where you see Downloads click where you see Click Here
Fill in the needed information and Linksys will take you to your software. At the above site under the search window is a blue bar. Listed there is a link to Learning Center. All the help you need to get up and running. One point, if you are going to use the wireless end of the router, setup a secure site with password protection. That will keep neighbors & others from tapping into your bandwith for free.
Enjoy!
Please vote...
6ya staff
SOURCE:
Ad hoc router WRT54GX4
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 31, 2013 | Cisco Linksys WRT54GX4 WirelessG Broadband...
I LOST MY Linksys WirelessG ADSL Home Gateway WAG200G Wireless router CD
Download the firmware from the Download tab after following the link. You should be able to find user guides and other help for your router there too. Downloading the firmware should allow you to use the router. The CD just contained that info.
Link
Nov 29, 2012 | Linksys WirelessG ADSL Home Gateway...
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
Hello, my internet service provider gave a preinstalled modem to use, however I would like to use my Linksys Wireless - G ADSL Home Gateway to be able to connect my devices to the internet wirelessly......
No. Your wireless router will not be recognized as a modem, nor will your service provider allow it if it would work. Plug the router into the modem.
Plug a cat 5 wire in from the yellow jack on the router to the same on the modem (it may not be yellow). The rest is software. Reboot everything and run the wizards depending upon the version of windows you are using, which you don't mention, BTW.
Your service provider may offer to help you set up your home network. Give them a call.
Thanks for your question @ FixYa.com
Aug 04, 2011 | Linksys Wireless-G WRT54G Router
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
Would like to get my wireless network secure, I have a Linksys WirelessG 2.4Ghz Router
If your linksys router came with a disk insert it into the cd drive then follow the instructions from there
Aug 30, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
443 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
