Question about Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 won't recognize paper tray
I know - we need to get rid of this machine.
NEW PROBLEM:
Main paper tray is not recognized by the machine. It is there, it has paper, and yet the machine does not see it.
  • 2 more comments
  • jakeami Jan 25, 2008
    Must have been the gremlins-the machine acts as of that tray is not even there (even in manual mode).
    BUT - the instructiosn above must be for a slighty different machine:
    No "Function" button on this one.
    Original Size: there are 4 buttons (Ledger, Legal, Letter, & Invoice)
    Sounds like this is what I need to do - get into the Function mode, but need a different key combination!
    HELP
    I was able to get into the function menu and make the change, but I can't get out of the function menu!! Even turning off the machine, waiting a few minutes, and turning it back on doesn't work.
    I tried "User Preset + Orginal Size (ledger) +3" and that doesn't work. No individual key seems to work.
    HELP!!
    I had trouble getting out of Functtion mode - but finally found a key combination that worked.
    Still no luck - I changed F5-14 from 1 to 4 and it still doesn't see it.
    Currently:
    F5-14=4 Letter-landscape orientation installed
    F5-15=1 Letter-regular orientation installed
    F5-16=0 Legal tray installed
    F5-17=0 (no tray installed)
    F5-18=0 (no tray installed)
    Is it possible that F5-14 through 18 are the wrong place for the tray settings? I say that only because F4-14=4 didn't change anything AND because F5-16=0 is working fine with legal even though it appears the setting should be F5-16=2.
    Also - now the copies all have dark blotchy areas all over. Not sure if I accidentally changed other setting(s) while I was trying to deal with the paper tray issue.
    I got that figured out (finally) - see my additional comments above. The paper tray is still "invisible".
  • 25 Answers
Can you hear the tray rise when you close it? Is there a red, blinking "out of paper" light on the control panel? Can you select the tray manually?
Or, you had a power outtage, or gremlins, and the settings reset itself, you can go in to service mode and set the trays up again.
Hold the following keys to fire up Function mode. "Function + Original Size + 3". Hit 5 for F5 mode. F5-14 is tray 1. If you have a duplex(ADU) unit installed, you'll want to check out tray 2. F5-14 is tray 1, F5-15 is tray 2 all the way down to F5-18.
Key in whichever number you need.
0: none (no tray installed)
1: Ledger
2: Legal
3: Letter
4: Letter-R (landscape)
5: Invoice
Posted on Jan 25, 2008
  • 1 more comment
  • Mitch S
    Mitch S Jan 25, 2008
    You want to use the "Original Size" top, left button (Ledger). I didn't mean function, I meant User Preset. It's Function on the newer ones.
    So it's User Preset + Original Size (ledger) + 3
  • Mitch S
    User Preset + Clear will get you out of service mode.
  • Mitch S
    If that's the case, you'll need a tech to come out and look at it. Those machines can be erratic for no reason. And the nasty looking copies could be any number of things.
Panasonic fp-7735 is working good but if i make a copy the paper copy result is complete black
Check and see if the light under the glass is lighting up. If not, that is your problem.
May 15, 2011 | Panasonic FP-7735 Black and White Copier
My Panasonic FP-7160copier is showing code: c0210. What does it mean?
C0210 indicates a problem with the Transfer/paper separator corona unit.( the one below the drum)..it is either dirty, not installed properly or may need replacement.
Nov 05, 2010 | Panasonic FP-7735 Black and White Copier
Error Code U 6
Error code U-6 means the door on the RHS of the machine is not closed properly.
Jun 24, 2010 | Panasonic FP-7735 Black and White Copier
I like to sell it itr wors good Panasonic FP-7735
please consult your local newspaper to advertise. this is an old copier with old technology .
Apr 18, 2010 | Panasonic FP-7735 Black and White Copier
ERROR CODE E340 BLINKS WHEN MY COPIER ON
clean sensor beside drum then switch on machine with white paper on glass.
May 05, 2009 | Panasonic FP-7735 Black and White Copier
Drum for FP-7735 HELP?!
Would reccomend that you get a technician to do this as he will need to reset settings in the copier.
Dec 13, 2008 | Panasonic FP-7735 Black and White Copier
Help me with a code reset panasonic fp7713
Press paper tray, zoom down key, and #1 keys simultaneously. "F1" displayed. press 8, start,then 09, start. DV will run auto for 3 min. hit stop/clear. F7-22 to clear PM count.Press stop/clear until F1 displayed. Press paper tray, zoom down, and stop/clear to exit maintenance mode.
Sep 08, 2008 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 trouble shooting
That could be a few things. Your corona wires might need replacing. Something with the middle transport section, where one of the corona assemblies is at, is not making contact properly. Or it could be the high voltage power supply.
Nov 05, 2007 | Panasonic FP-7735 Black and White Copier
Fp-7713
press and hold paper tray,zoom down,1 simultaniously you will enter in programe.F will come on display press 6 it will appear F6 press stark key change the value and then start key to exit the program press and hold these keys paper tray,zoom down stop key
Aug 27, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic 7735
Hi Yes can help but need to know the code. If you open and close front cover machine should reset.If not need the code
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 Black and White Copier Logo
141 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
