Question about Ezonics EZCam III Webcam
Registration Problem When I try to register my EZCam III I get the following error: "Ping server timeout, please check your network and try again." I do not have a network (single laptop). Has anyone encountered this problem and is there a solution?
  • 64 Answers
  • Bandwidth problem, if you use dial up 56k you could be timing out the response to their servers.
  • You might be running a firewall program - ( some later versions of windows have an inbuilt firewall )
  • The firewall if you have one, should be showing on the task bar, i have included a picture of one to help work it out.
    • Once you identify your Internet security program
    (firewall) you can simply right click and pause your protection, or disable it whilst you attempt to register your EZCAM product again.
  • If all else fails look on EZCam's Website page for their contact details and perhaps email them or if they have one nearby, you might be able to telephone them with your problem.
I truly do hope this helps you get to the bottom of your problem, and if we have helped you, please take the time to rate this response, thank you. :)
Posted on Jan 24, 2008
Mcafee installation retail card
How do I register my product?
Issue Description Product registration normally occurs during the installation process. To register your product, you must be connected to the Internet during installation. Please note that Microsoft Internet Explorer 6.x or later is required to register your product. You can download the latest version of Internet Explorer at:
If you receive a 500-100 error or an error that states A network error was encountered, please try again later, remove any non-alphanumeric characters (& ??? '' < > #) from the text fields in your registration form and try registering again.
Solution If the registration wizard does not display after the installation of the product, please follow the steps below:
  1. Right-click the M icon on your taskbar.
  2. Select Check for updates. If you have not registered your software, you will be prompted to register before obtaining your updates.
    NOTE: You must be connected to the Internet to register or update your product.
  3. When the McAfee Product Registration window displays, click Next to continue with the registration process.
  4. Complete the product registration form to proceed with updating the product.
After your product is registered, it will automatically update when connected to the Internet.
Jul 19, 2014 | Mcafee LiveSafe Unlimited Devices
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
Printer is offline
What type of printer are you having a problem with? Is it on and do you see any error messages on the printer? How is it connected to the computer? Do you have the driver installed? Some printers need to have the driver installed with a USB connection before moving to a network install. (For all-in-ones, the driver/software must be installed before you connect the data cable.)
If a wired connection, try new cables (fully seated) and different ports. If it is a USB connection, try a direct connection if the printer is connected to a USB hub or print server. Make sure that the cord is 6' or shorter. Check if other devices work. (I've seen a few computers loose their USB ports for no apparent reason. On desktops, try rebooting the computer and uninstalling the USB drivers and rebooting again. This is in the Device Manager for Windows machines. On a few laptops, sometimes removing the battery and the power adapter will reset the ports.)
For network connections, make sure that your network is up and that you aren't getting signal loss issues (for wireless networks). Try a wired connection to check for network loss. To check a network, I tend to check a few points with the ping command. For Windows, launch the Command prompt and ping the numerical IP location of your router. Then ping the IP location of the DNS server. Can you see the printer on your list of network places. (The format for ping is
ping or ping followed by enter. The returned message will be either the time for a small packet of data to go to the location and return or a connection timed out.)
If you are losing your network connection, reboot your router and broadband modem. (Try rebooting the router first.) Make sure your firewall is not blocking access to the printer.
I hope this helps. Please write back for more information with specifics for your printer.
Feb 12, 2011 | Office Equipment & Supplies
I have installed the ezonics web cam in my system. I have completed the driver installation process.When Iam trying to switch on my web cam it asks for a user id and password..What user id and password...
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jun 27, 2010 | Ezonics EZCam III Webcam
Network Problem (occasionally loss)
Are all clients losing connections or just one? Can anyone ping the server when your client is getting 75% loss? If you are using a hub, what traffic is running during packet loss? You might need a packet trace to see what is going on. You also need to check your server stats when it is happening and when it is not and see what the difference is. Check the hub stats for errors on the ports. Is the server on the same hub with your client? These should help you find the problem if you get this info.
May 11, 2009 | IBM eserver xSeries 205 8480
I just figured out what you ment
Possible Cause Action
The SMTP server is not in
Check with the network
IP address of the SMTP
server is wrong.
administrator and enter the
correct IP address.
Port number is wrong.
correct port number.
A timeout condition occurs.
Set a longer value for “SMTP
Connection Timeout.” The timeout
value depends on the
network’s traffic conditions
and load on the FTP server.
The network is disconnected
during file transfer.
Send Ping from PC to the controller
and SMTP server to
check to see if both parties are
connected to the network or
For any clarification on the procedures.
See “User’s Guide
[Network Scanner
Jan 06, 2009 | Konica Minolta bizhub C250 All-In-One...
I'm using IE 7 and Firefox 3. I'm able to pull up all websites i type in but one on my desktop PC. The error I'm getting is "Page Load Error" Network Timeout The server at .com is taking too long to...
try to ping it,
go start then to run , type "CMD"
then type "ping"
if there is any reply so ur ISP is working fine
if not try to put the DNS server address in that pc manually,
and check if there any installed personal firewall
Dec 21, 2008 | Computers & Internet
i can't afford your premium plan at this moment and no,,,,,,i have not solve this problem,,,,this is why i am writing in hope that you can help in me solving it. I tried again this morning the same is happening
Jun 01, 2008 | Ezonics EZVideo Chat Kit Webcam
Ezonics EZCam III Webcam Logo
147 people viewed this question
Top Ezonics Computers & Internet Experts
micky dee
Larry Maranto
Mark Gough
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
