Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
No power i have been watching the telly all day and then tuned it off or a few hours but let it on stand by.I then went to tun it back on and i just heard a "bink" and the red light went off......thee is now no power what so ever.please help!
Hey trying doing a product update download from philips using a thumbstick they seem to give updates for this tv a couple times a year, ive seem to rembber this issue being resolved in a update worth a shot, just plug it in on the side the tv should reckonize it .
Posted on Feb 04, 2008
Mitsubishi cold 3.0 v6 workshop manuals
If your philips tv keeps losing it's stations when you switch it off, this my be a solution -----my 42" tv would need to be retuned every time I wanted to watch it this fault just started over night it was all working fine then sat down to watch tv and had to retune tv from scratch I could then watch telly all night fine change channels no probs all great switch it off next day retune and so it went on if you have this problem switch telly on then hold in menu button on tv until screen goes black (this reboots software) then retune tv as normal it will ask if you want a full retune (yes) when this is complete digital and analogue your tv should now remember channels when switched off and work as it used to ----( Hope this helps you if you have had this problem it worked for me ). Good Luck
May 29, 2014 | Televison & Video
No picture
this could be a cold solder or something a simple as a fuse inside the telly how old is the telly and are you confident in taking them apart and looking for the problem yourself as these tellys work at a high voltage witch does kill they are still live even after they have been unplugged for 24 hours so i would leave the telly for 24 hours then i would take the back off and where the power lead goes into the boadr there will be two fuses check both of these and replace if needed if you are not confident in taking the unit apart take it to a shop as their is a lot of things you need to undo but first try the controll if you cant do nothing on controll then it is fuse or a solder problem could even be high voltage problem have you still got the stand by light on the set if you have then it is a high voltage problem witch is difficult to tackle without proper testing equipment if you have equipment i could talk you through how to do and what to test but if you by the equipment you are talking a few grand it shouldnt be that expensive to get repaired at shop i would have thought about 75quid witch is cheaper than destroying the set if you dont know what you are doing post back if you need to hope this is some help.......................................................
Nov 08, 2007 | Hyundai ImageQuest HP4240 42 in. Plasma...
Tv powers up but goes directly into stand by mode
An Electronic component has failed. Unless you can repair circuits, take it to a shop or friend who can. Consider cost of replacement. A few hundred will fix an old tv, a couple more and you have a whole new unit.
Nov 16, 2013 | LG 42PQ30 42 in. Plasma TV
I have a LCD 42" telly. I had it few years now.
Your telly has died a noble ***** and may need to be retired.
T con board is responsible for images portrayed on screen.
Aug 25, 2017 | LG 42LC2D 42 in. LCD HDTV
I have a 1980's atari game. How do I set it up?
hi, this round pin with the little pin in the middle this needs to be plugged into the back of your telly it goes into the ariel socket you need to unplug your tv's arial then plug this into where the arial was, now what you need to do is put your telly onto a channel you dont use such as 7 or 0 witch ever one you dont use to watch telly, once you have done this you need to enter the setup mode on your telly to scan for channels so make sure the game is switched on and then start scanning for channels as if you were tuning in the tv channels so do this then you will come across the game so you then save this frequency to this channel.
You can then play the games just remember when you want to play it that you put the telly back onto the channel you tuned in for that game.
Let me know how you get on or if you need further assistance ok
Jan 25, 2010 | Video Game Consoles & Games
ViewSonic P815 scren suddenly went black
either the bulb/tube has deteriorated. or long shot but happened to our old telly and that was, the power cable solder joints had worn loose.
If you feel capable of yeilding a solder gun then read on.
ANY LOOKING OR OPENING UP OF TV CASES MAY VOID ANY WARRANTIES. YOU MUST UNPLUG ANY POWER LEADS AND AVOID TOUCHING THE TUBE END INSIDE THE UNIT AT ALL COSTS. speech over we shall continue...
remove back of telly and carefully arrange screws in a circle shape to mimic their removal locations. trace the power lead cable physically by following the lead to the motherboard. to the man in the street thats the platform where all the components sit. the cable will be soldered to this board. visually check to see if there is a sound solid solder joint, marrying the two as one. if these are loose then you might be in luck.
resolder joints, cleaning off any residue of flux. replace back cover and power up.
Hope this helps
AndystUK
Oct 24, 2009 | ViewSonic P815 21" CRT Monitor
I have a sega mega drive with all the relevant pieces but i cant tune it into the tv
Hi. is the lead from mega drive a rf socket that goes into the arial socket on the telly and does the lead have a switch on it?
Plug the rf lead from md into areial socket on telly
then put telly on channel you dont use i used 0 or 9 but use any.
then turn mega drive on
then press setup on tv
enter channel settup then you need to go through the procedure of tuning channel in its best doing it manualy its like when you tune a channel in make sure md is on then keep changing the frequency one way or the other could take few minutes then when you get it on the telly save this setting on the channel you want to use ok.
If it dont work then the chances are the lead is damaged this is often the case with these consoles as the are not made that well so if no good then replace if necesarry.
If your unsure on tuning your telly then give me make and model then i can talk you through the process ok
Apr 22, 2008 | Video Game Consoles & Games
Sony tv not turning on
I would need the model number to look service codes
Feb 24, 2008 | Televison & Video
Tv is on stand by but won't 'fire up'
I don't know the age of your set but I've found some Panasonics with a loose connection on the heat sink (an aluminum plate standing vertically on the circuit board) of the regulator IC (chip). The IC gets its ground through the heatsink. If the ground is open the power supply puts out too much voltage and causes the set to go into shut down. I've found this problem several times. Stargazer
Jan 22, 2007 | Panasonic TX-28DK2 TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
