PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Memory (RAM) issue
By teddy0038 on Jan 24, 2008
I had only one 256mb, I replaced with 2- 512mb and now my computer is only recoginizing 512mb. What do I need to do to get it recogize the entire 1gb of memory???
Terry
Comments:
Jan 24, 2008
- Oh, this laptop is a IBM Thinkpad T30 Model 2367-GU3
Jan 24, 2008
- They are the same memory brand chips, both are 512mb, pc2100. I am thinking that one of the slot the additional is not working. It recogizes only one stick.
Solution #1
posted on Jul 03, 2008
Not Rated)
Hatch4ut
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem and the only reasonable solution is to send the unit back to fix the motherboard. I bought two 512 MB modules, installed them both for a total of 1 GB, only to have the machine recognize 512 MB. After swapping the modules around and even depopulating all memory, I found that the slot closest to the front is not working. When I populate a module only in that slot, the BIOS beeps a memory error code when powering up the machine. I've read other posts that claim this is a latent defect in this model. Some folks have even had their T30's degrade to where the once-working front slot no longer works. Hope this helps.
Was this helpful?
Yes
No
Solution #2
posted on Jan 24, 2008
Not Rated)
DarkNeogen
Rank: Guru
Rating: 87%, 132 votes
How many RAM slots do you have? Are they coloured differentlly? For example 2 blue, 2 black. If so.. Put one 512 MB DIMM in either a black one or a blue one, and the other DIMM in the other slot of the same colour.
I hope this solves your problem.
Greetings,
DarkNeogen
Comments:
Jan 24, 2008
- Oh Sorry, I misread. The above isn't appropriate for a notebook. Check if they are both connected properly.Are they both of the same type?
Greetings,
DarkNeogen.
Jan 25, 2008
- You should try to switch 'em. Use the memory bank that was used with your 256 MB DIMM. Test both on that one. If they both work and you are completely sure you installed them both correctly then the slot is defective. Otherwise one of your memory modules might be defective.
Greetings,
DarkNeogen.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I am looking for a TRUE desktop-replacement. I am looking for a quad-core min 4. GB of DDR3... (More)
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
My HP Quickdock is no longer recognizing my second monitor. If I pick up the Quickdock and move it... (More)
Answer
i have a black volume rectangular box with bars flashing right in the middle of the screen. I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
