Question about NEC Dterm DTP 16D-1 Corded Phone
Speed dial setup
I need to know how to set up a speed dial number
  • Anonymous Feb 21, 2008
    need to set up speed dial numbers in comtrac phone
  • Noel Coward
    Noel Coward May 11, 2010
    What model PBX is it connected to are they programmed on your phone as SPD
  • 35 Answers
What model of PBX is it connected to?
Posted on Apr 19, 2009
bestdarngood
  • 3037 Answers
SOURCE: How to set numbers on speed dial
Main support number 1-800-338-9549, I'm sure they can help you
Posted on Mar 19, 2008
SOURCE: Setting the speed dial numbers
Dial Feature *4
Enter the speed dial code (71-94)
Press a line button or a pool button
Dial the phone number desired
Press hold or OK to finish
Posted on Nov 19, 2008
SOURCE: Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Posted on Nov 29, 2008
Chipstr
  • 153 Answers
SOURCE: I need to know how to program the numbers into
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Posted on Feb 02, 2010
Phonesmith
  • 113 Answers
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Posted on Mar 24, 2010
Need to know how to fax from mcf 210c
How to enter Fax mode
Before sending faxes, make sure (Fax) is illuminated in
green. If not, press (Fax) to enter Fax mode. The default
setting is Fax.
How to dial
You can dial in any of the following different ways.
Manual dialing
Press all of the digits of the phone or fax number.
Setup Send
3 - 2 SETUP SEND
Speed-Dialing
Press Search/Speed Dial, #, and then the two digit Speed-Dial
number. (See Storing Speed-Dial numbers on page 5-1.)
Search
You can search for names you have stored in the Speed-Dial
memories. Press Search/Speed Dial and the navigation keys to
search. (See Storing Speed-Dial numbers on page 5-1.)
* To search alphabetically, you can use the dial pad to enter the first
letter of the name you are looking for.
Fax Redial
If you are sending a fax manually and the line is busy, press
Redial/Pause, and then press Black Start or Color Start to try
again. If you want to make a second call to the last number dialed,
you can save time by pressing Redial/Pause and Black Start or
Color Start.
Redial/Pause only works if you dialed from the control panel.
If you are sending a fax automatically and the line is busy, the MFC
will automatically redial one time after five minutes.
If the LCD shows Not Registered when you enter the
Speed-Dial number, a number has not been stored for it.
Color fax transmission
Your MFC can send a color fax to machines that support this feature.
However, color faxes cannot be stored in the memory. When you
send a color fax, the MFC will send it in real time (even if Real Time
TX is set to Off).
Nov 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
Nov 18, 2010 | Brother IntelliFax-4100e Fax
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I do a group fax with a M20i?
NOTE: The following solution applies only when the WorkCentre has the fax feature.
Speed Dial numbers must be set up before creating a Group Dial. If Speed Dial numbers have not been set up, See the Related Items below for additional information.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up] or [Down] arrow button until 'Fax Setup' is selected, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Group Dials' is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until 'New' is displayed, and then press the [Enter] button.
  5. Enter a Group Dial number between 1 and 200 using the numeric keypad, and then press the [Enter] button.
    NOTE: If a 'Location No. is Registered' message is displayed, the number has already been stored as a Group Dial. Enter a number that has not been stored, and then press the [Enter] button.
  6. Enter a Speed Dial number to be added to the Group Dial using the numeric keypad, and then press the [Enter] button. The name and fax telephone number stored for the specified Speed Dial number will be displayed.
    NOTE: If a 'Not Assigned Enter Again' message is displayed, the number has not been stored as a Speed Dial number. Enter a number that has been stored, and then press the [Enter] button.
  7. Press the [Enter] button. The Speed Dial number will be added to the Group Dial.
  8. Repeat steps 6 and 7 to add additional Speed Dial numbers to the Group Dial.
  9. After all required Speed Dial numbers have been added to the Group Dial, press the [Menu / Exit] button.
  10. If required, enter a name for the Group Dial using the corresponding buttons on the numeric keypad, and then press the [Enter] button. If a name is not required, press the [Enter] button.
  11. Press the [Stop] button to return to the Standby mode.
Feb 17, 2010 | Xerox WorkCentre M20i All-In-One Laser...
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
STEPS NEEDED TO PROGRAM SPEED DIAL
For speed dial go to Main Menu >> settings >> initial setup >> Speed dial >> Phone Memory.
Than transfer numbers which you want to assign as speed dial in Phone memory.
Goto particular contact and edit the number and assign it as Speed dial.
May 20, 2009 | Motorola Mobility RAZR V3
How do I set speed dial numbers?
Here is the procedure to setup speed dials (both individual and group) on your printer.
thx
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Using a calling card for a long distance fax
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Apr 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
Motorola A1200
while pressing a number in dialing dont press it continuosly for more than 3 to 4 seconds otherwise it takes number as turbo dialing number.
In setup(in the dialing menu where numbers are displayed) there is facility of turbo dialing i.e. speed up dialing such that you provide phone numbers numbers between 1 to 9 for example in 1st number you provide number of your dad then when you press 1 continuously then your dad's number gets called. So, as you have not set your turbo dialing this message has appeared.
Nov 03, 2007 | Motorola Mobility A1200
One touch dial or speed dialling.
Hi Menu => Contacts =>Speed dials. Good luck.
Aug 28, 2007 | Nokia 1100
NEC Dterm DTP 16D-1 Corded Phone Logo
306 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
