Question about Kenmore 72073 Top Freezer Refrigerator
Refrigerator Have you ever seen a refrigerator bulging on each side? It's pretty old and probably needs replacing, but am just wondering what is making the sides bulge out. There are also some popping sounds.
  • louweez Jan 25, 2008
    i surmise that the bulging sides will continue and eventually will cause damage to the wall and counter on either side of it. Have you heard of this happening before? Is it time to replace it?
    Louise
    Many thanks for your opinions -- much appreciated.
    President:
  • 1,314 Answers
Yes i have its from over foaming used to happen a lot in the old days are the poppins sounds when the compressor firsts cuts on if it is its from freon expansion and you can get a sound damping pad and put around the line's comming in to the evaporator
Posted on Jan 24, 2008
  • robert samples Jan 25, 2008
    well if its really old you might consider replacing it just because the newer ones are more engenry efficient but long as it was cooling good id use it till it didn't the expansion should have stopped by now
    your welcome
Refrigerator side bulge
Hello Melody Vandiver....
I'd go back to the full defrost (THAT BULGE SHOULD RELAX).
BE PREPARED for some un-controlled "defrost" WATER.
Towels... wet/dry vacuum... etc.
Somehow (I think) you have a water deposit in the lining of
your refrigerator... Since the INTERIOR (REFRIGERATED ENCLOSURE) SHOULD BE AIR tight...
It might prove to be SERIOUS CHALLENGE to find ... remove and re-seal the EXTERIOR case (WIRES & TUBE passages into the
refrigerated area.
Carefully inspect doors (drawer if you have them)... that their gaskets have full contact all the way around & the doors are square with the case.
Do the "dollar bill" test (brown paper sack is much cleaner & nicer than MONEY)... pull a piece of paper... all around the closed door. You should feel resistance at every location"
It can occur if the refrigerator was tipped on it's side during transport... or you have sustained a CASE AIR-LEAK that is allowing FROST TO BUILD UP in an UN-HEATED (DEFROST HEATER) area.
If my hypothesis is EVEN NEAR close...
This is most likely adjacent to your freezer compartment.
(although I'm at a loss as to why it would bulge OUT rather than into the softer and more flexible plastic (I assume.. no make or model came through with your question) interior lining.
Use no external heat sources on the unit...
Unless you are really good at taking PICTURES & NOTES... this might be a job for a trained "SERVICE" person.
I ORDNARILY ENCOURAGE doing-it-yourself....
but your problem sounds pretty drastic.
I'm just and old side x side guy so I don't speak dual evaporator.. web-enabled remote video-access refrigerators...
(nor care too (twice retired from advanced electronics/optics)... these latest gadgets seem a bit 'round the bend 4 A Frig))).
Good luck... comment me back if you are going in...
and remember to take pictures & notes so you can get every tube & wire PRECISELY BACK from whence it came!!
Sears service (I don't personally like'em (IMLTHO)).
Water Filters Lawn Garden Appliance Parts
Jul 17, 2016 | Frigidaire Refrigerators
Fridge wall bulging
Sound like the foam insulation has expanded during mfg...should just be an appearance problem, but it is no excuse for it.
May 01, 2014 | Refrigerators
My GE side by side is making a terrible humming noise similar to some of the other posts I have seen. Are the fan motors easy to replace?
The fan motors are usually pretty eay to change. Need to know model number and which fan to help you change it. Please comment me back so I can assist further.
Jul 28, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Iam wondering about my old refrigrater. its rounded, standing at about 4'8. brand " deepfreeze" refrigerator. its old, pretty vintage. wondering if you knew a link i can find information on this,...
Yes this is an old fridg. There are thousands of them in the US being used as secondary cooler for pop, beer, ect. in garages. The problem is they don't ware out. The major problem is the cfc refigerant that was used is now outlawed, and they are not efficent by today's standards. For a little bit more of electric usage, and if it still works and , and it does it's job and you are happy keep it.
It will cost you more than it is worth to hall it away and do the reclmation of the cfc gasses even if it is an antique? Don't you wish they would make appliances today like GE did then?
Hope this helps you making a decision. If it was mine I'd keep it (if you have the room)
Dec 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works but refrigerator does not
First, open the freezer and look for a snowy frost build-up. See if it's bad enough to cause bulging in the inner panel at the back. If so, you may have a defrost problem. Also, make sure nothing is blocking the ariflow between the freezer and fresh food sections.
Listen to see if the compressor is running. If it is, open the refrigerator side and turn the freezer control off, then back on, three times within six seconds. Did the compressor stop running? If not, the problem is very likely the adaptive defrost control board. Replace it.
If it does stop after "forcing a defrost cycle", you probably have a burnt-out defrost heater. It will need to be replaced.
Dec 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Have a 6 - 7 year old Samsung RS2534WW from Best Buy. The back interior wall of the fridge is bulging forward/inward for quite some time now. We had to remove some shelving in order to be able to close...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Samsung RS2534 Side by Side Refrigerator
Refrigerator is not cooling properly-temperature is not in the "safe zone". freezer seems to be working fine
There will be a fan on the freezer side which blows cold air into the refrigerator side. Make sure that this fan is turning. It will probably be at the top behind an access cover. If this fan is not turning, you will likely have to replace it. These fans are readily available at internet appliance parts stores and are not too expensive. Replacement is pretty easy. The fan is probably held in place with 3-4 screws, and there will be a plug-in power connection.
Apr 20, 2010 | GE 25.4 Cu. Ft. Side-by-Side Refrigerator...
Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Jun 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have no power to the refrigerator light or the digital controls
your actual problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replaing the control board. thx peyton
Jan 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 72073 Top Freezer Refrigerator Logo
299 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
