Question about Sharp AR-5320 Black and White Copier
Sharp AR-M350N/H5-01 I understand that this error code (H5-01) happened from paper jamming in the same area five times. However, I don't know how to reset the code? Also, the code on the product is not right one as far as I know. The code on the subject is the correct one.
  • 61 Answers
Hi, to reset H5 follow this sequence: P, *, C, *, display should read 'enter simulation', enter 14, print, execute, yes. Should re-boot if not switch off then on.
Cheers
Andy
Posted on Jan 25, 2008
Hallo i have a problem with my sharp SF 2530.
the problem is H5 in the display
Help me
Posted on Mar 28, 2008
Why is my sharp mx 3500n copying blank pages. No error code indication
check the transfer roller/transfer assy or replace the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 28, 2015 | Sharp Office Equipment & Supplies
L6-10 code
Paper jam at exit of the shifter unit.
Aug 26, 2013 | Sharp AR-M350N Black and White Copier
MY AR-M350N COPIER DISPLAYS F1-15 ERROR CODE, IT ALSO SAYS THAT THE FINISHER IS OUT OF SERVICE. PLEASE I NEED A SOLUTION TO THIS PROBLEM
The error code F1-15 means that the stapler is not in home postion. It can also, be that the exit tray is not in "HP" aswell. I would turn the copier off and turn it back on and not use the stapler funcation. To repair the problem, there are a bunch of up dates to resolve this problem. I would change the out put tray from the finisher to the left out put tray... Good Luck
Mar 17, 2012 | Sharp AR-M350N Copier
H5-01 Error, I need to clear this. How do I enter tech mode, I know the sequence is P# - * - C - * - 14 - start - execute. Its a sharp AR C 260
Did you open the left door and clean all the paper out of your fuser and exit area? If you cleared paper and code and get it again either your fuser needs a rebuild or your transfer belt if not moving paper through fast enough. H5-01 means five consecutive attemps to send paper through the fuser have failed.
Aug 03, 2010 | Sharp AR-C260M All-In-One Printer
Copies get stucked in sharp ar-m350n fuser
check the fuser roller gears ,the impression between the two roller and the paper seperators one of these is not in good shape.
Feb 21, 2010 | Sharp AR-M350N Copier
Sharp AR-M350N memory?
AR-M350N may be have 16 Mbyte of internal memory.
You could expand it until 256 Megabyte.
I attacched to this post an image that describe compatible expand memory.
Nov 03, 2009 | Sharp AR-5320 Black and White Copier
I have System error E007 problem in my Canon iR-2016 copier machine?
Hi
Thanks for using FixYa. Error E007 means there is a jam in the Fixing/Fuser Assy. Error E007 is related to a non-detection of the Fixing Film/Upper Roller, the fixing film sensor didn’t detected the rotation of the film for 6 sec or more while the fixing motor is driven. Please check the condition of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. If everything is fine then try clearing the error by entering the service mode, you can do it by pressing *(star), then press 2 and 8 keys at the same time & then press *(star) again.
Now press COPIER>FUNCTION>CLEAR>ERR, to clear the error code.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | Sharp AR-M350N Copier
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
Sharp AR-5320 Black and White Copier Logo
3,628 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
