Question about Sony Cyber-shot DSC-N1 Digital Camera
MY N1 LCD GONE WHITE
HIIIIIII THERE , I HAVE N1 CAM AND FROM 1 MONTH FEW DROPS OF WATER ENTERED IN THE CAM AND I CAN SEE IT BEHIND ME TOUCH LCD HOWEVER THE CAM WORKED JUST FINE WITH FULL FUNCTION. BUT LATELY THE WHOLE SCRENGONE WHITE AND THIS WHITE IS TRANSPARENTAS I CAN SEE THE MENU BEHIND IT AS LIGHT REFLECTION BUT IT WORKS FULL FUNCTION EVEN THE TOUCH INTERFACE WORKS WELL BUT ONLY THE SCREEN IS WHITE SO WHAT IS THE PROBLEM U THINK , DO I HAVE TO CHANGE THE LCD OR WHAT
You have a damaged LCD screen ..
goo & get it fiiiiixed. yourwelcome .
Posted on Jun 18, 2008
Gray screen
The liquid has damaged the screen driver chips on the rear of the screen. Replace the screen.
Jan 29, 2014 | Toshiba Qosmio Computers & Internet
Tip
What to do when your coffeemaker stops after just a few cups
When coffeemakers make only a few cups of coffee instead of the whole pot, it's usually because the heating element is covered with hard water deposits. To fix it, you just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
The cause of the slow brewing is that the water you normally use has some amount of hardness to it, and over time the hard water minerals build up on the heating element inside the machine. The buildup prevents the heating element from heating the water as fast as designed. The vinegar will dissolve the minerals and let the heater work at full capacity again.
If you want to avoid this in the future, just run the white vinegar through it once a month or so even if it's not running slow.
on Jan 31, 2010 | Coffee Makers & Espresso Machines
Screen suddenly turn white and done all that i could like hard reset but when i switch it on again, it was normal only for a few seconds before turning to white screen again...
If you you are experiencing white screen and nothing changes even after doing a hard reset you may want to call or contact HTC support. Be sure that it is still cover by their one year warranty. Coz having a white screen might caused of a lot of things like infected by virus, water incident, mobile phones has a physical damage. Check as well the lcd of the phone. try to get in touch with them with the link below.
http://www.htc.com/sea/CA_Hotline.aspx?region=NorthAmerica
Mar 16, 2011 | HTC Touch P3450 Smartphone
My lcd monitors turns on for a few seconds when i start my computer then turns black what is wrong with it
if it's new then get it replaced...
else u need to get it fixed from a tech shop....one of the below is @ fault....
1 the LCD screen is gone,
2 the backlite (a small tubelite) is gone
3 the invertor board(a small PCB) behind is gone
May 08, 2010 | HP w1907 LCD Monitor
My nokia 3110c was immersed in water and refused to turn on, after few month when i trie to switch it on is bring message "contact service" can i get help on this?
When a phone falls into water, there things that needs to be done fast in other to prevent damage on the phone because water is not friendly with phones.
Why contact service came up was because the phone was not attended to earlier.
When a phone drops into water, first you need to remove the battery in other to prevent I C in the phone to bridge, depending on the capacity of water that entered into it, some might make the phone start getting hot.
The phone you are using has two option:
servicing the phone,
or
the phone might not stop showing contact service.
When you service the phone, the contact service might go off or might still be displaying the phone.
It is a 50-50 trial, might work or might no work.
Take care and good luck.
Mar 21, 2010 | Nokia 3110 Cellular Phone
No Picture on 5 month old tv.
If the screen is just showing white screen, no text, no picture, then the problem cam be in the LCD controller board. I would get this fixed under warranty ASAP, nothing should have gone wrong yet. You may have a lemon, this is not a no name set.
Jan 02, 2010 | Toshiba 26LV610U LCD TV
Water marks and dust on the INSIDE of Nokia 6085 LCD screen
Brother Frist Time I Am Faseing Problem Like This Its Unbelievable, Go 2 service Senter & Chaque Handset For Other Dameges.
Mar 31, 2009 | Nokia 6085 Cellular Phone
White gunk in rocabox cover and water drops and in crank case is the head gasket gone .
yes you either have bad head gasket or crack in the head..sorry to be the one to let you know .. hope it helps you anyway..keith..
Mar 14, 2009 | 1995 Volkswagen Golf
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
SONY DSC-N1 LCD GONE WHITE
you can try blowdrying it just take off the batteries
Jan 17, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
49 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
