Question about X2Gen MG19MY 19" LCD Monitor
X2gen monitor Hi, I have a fairly new x2gen 19" wide screen color monitor.  I have it hooked up to my hp laptop.  Now the problem: Much of the time I am getting the weirdest ripples running across the screen, like water on a pond. Sometimes they seem to be running left to right, and then the other way. This may be an optical illusion. But as I cannot get thru to x2gen I was wondering what I can do to stop it as it is serious headache food. Any ideas?
  • Anonymous Feb 16, 2008
    I too have a X2gen monitor with the same problem as Lauren143 but mine also gets very dark sometimes . It is happening more and more. The screen willo flash darker and stay there theen sometimes ( like now) it's great. This problem is not (seemingly) related to screen saver as it will happen while I am working.
    Problem Solver:
  • 14 Answers
Hey I've read about your problem cus I had same thing weird lines flying on the screen from one to the other side or crossed and I've found the solution ,there is not enough power strength coming to the monitor power supply because you have to many thong plugged to the same splitter ,just unplug the monitor power supply from this splitter and connect it to another power outlet ,not the same ,another and it should fix the problem at least it fixed my so good luck ,and sorry for my spelling cus I'm Polish ,but I'm trying!
Posted on Mar 28, 2008
Tengo un monitor de 17 pulgada x2 gen y lo compre sin control porque lo necesitaba y ademas lo dejaron buen precio y control no aparece en el pais y yo quiero comprarlo atravez de ustedes necesito saber que debo hacer para obtener un control del monitor
Posted on Mar 31, 2008
Those ripples are the monitor degausing. This is normal, the monitor defauses (ripples) routinely every so often to rid of imperfections and magnetic disturbances.
Posted on Feb 10, 2008
6ya staff
SOURCE:
I have x2Gen 19" LCD Monitor. I hooked up the
More likely to be the fuse for the backlight inverter circuits rated at 3.5 or 4Amps. It is PICO fuse.
The transistors that drive the inverter transformers may have been damaged, should check them out before installin a new fuse. In the mean time you can use 1 to 2 Ohms 1/2 Metal Oxide (MOX) resistor in place of the fuse, if the resistor overheatand open up then you have shorts circuits.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 19, 2010 | X2Gen MG19MY 19" LCD Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Black out
even i had this same problem.....its two 220uF25V capacitors and one 47uF35V capacitor located on the backlight inverter chip covered by a plastic shield. It works just fine now. Be sure you get the polarity right when soldering in the new capacitors. It is marked by a shaded in half of the outline on the board and a line on the new capacitor. This was on x2gen 19inch wide screen though so check the specs of the capacitors on yours first. They all together cost around $5 at Radioshack.
hope i was helpful thank you
hav a nice day
May 19, 2009 | X2Gen MG19MY 19" LCD Monitor
X2GEN MONITOR LIGHT ON AND CLICKING
Hi...there,
Well, it is seems your monitor backlight inverter got burnt... need to replaced a new one or repaired it.
Dec 01, 2008 | X2Gen MG19MY 19" LCD Monitor
Flickering
Hi...there,
It's seems you got a busted backlight inverter...
Oct 28, 2008 | X2Gen MG19MY 19" LCD Monitor
Out of Range
Usually with the resolution your computer's set resolution for ur display is to high for the screen
try using a different screen to change the frame refresh rate and resolution to ur monitor
Oct 21, 2008 | X2Gen MG19MY 19" LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
122 people viewed this question
Top X2Gen Computers & Internet Experts
Thomas F. Schneider
scramblepad
scramblepad
Ekse
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
