Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Mouldy rubber seal
My Nexxt washer is less than 2 years old, and the grey rubber seal rings inside the door are all mouldy. I have tried to clean them with many different products including straight bleach, but nothing seems to remove the discoloration. What can I do , short of replacing the rings?
By the way, I never have been able to figure out anything but the basic settings. Is there an independent spin setting? I have had loads that were too wet when they were finished, and I can't find a way to just run the spin cycle again.
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Regarding the mould; keep your door open after yur washing is done, (means dont shut it tight) it will help to dry the insides & prevent moulding. Only see your cat is not inside before starting a new wash.
And pl rate me if helped.................
Posted on Jan 25, 2008
  • prem mathew Jan 27, 2008
    Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line.
How do I get all the stains and crud/mold off the front side of the whole tup enclosure.?? The grey rubber outer ring ??
Try soda crystal solution and elbow grease or a sterilizing tablet( type u use for cleaning false teeth) on hottest wash your machine has do this regulaly as black marks are bacteria left after cool washes . If all this fails u will need to replace rim I hope this helps
Oct 29, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
Dec 23, 2009 | Washing Machines
The door seal is leaking. maybe a zipper or similar got stuck and made a small mesh in the grey rubber seal. Where can I get this part?
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 28, 2009 | Siemens WFXD8400UC Front Load Washer
Can you replace the door seal on the miele w404 washer as it is mouldy and we have been unable to clean it?
AND the door seal
Jul 28, 2009 | Miele W404 Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
306 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
