Mitsubishi VS 5001r 1989 won't turn on.
Hey there. My TV doesn't turn on. When I press the remote, you can here a "click" like it's coming on...but then nothing.
  • 8,617 Answers
Check the horizontal output and the low voltage regulators . Also push the input and menu buttons on the set in together hold for 5 seconds and see if the light blinks out a code. If it does let me know what the code is.
Posted on Jan 24, 2008
My dish remote will not work with my naxa tv
Hey sevenwindham,
If the remote won't work it may need to be programmed to the TV. You can personally look at the steps in the link below, just look up the model of your remote. The steps to program your remote are also provided
http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
If that doesn't work you can also try the Power Scan listed below.
Power Scan:
1.) With the TV on, press and hold the desired mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 0 then press STAR (*) and press and release the Power button.
3.) Press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, the TV will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
If you have any other questions let me know!
Tommy Faust
DISH Network
Jun 15, 2011 | DISH Network IR Remote Control
VS 5001R sounds like its gonna turn on but doesnt
This chassis model line had issues with the vertical output IC shorting causing shut down.
It also had issues with intermittent solder connections in the Horizontal Circuit. I would not try to fix it your self unless you are very familiar with Projection circuitry and electronics background.
Hope this helps,
Skyassoc
Jul 02, 2009 | Televison & Video
Tv turns off when it feels like it
There are 4 possibilities.
1. weak remote batteries
2. failing remote button pad
3. failing infra-red LED in remote
4. failing infra-red receiver in TV.
First, try another fresh set of batteries.
Next, replace the remote, third, have a TV shop look at it.
May 12, 2009 | Mitsubishi VS-45609 TV
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv wont turm on
If TV will not come on when you press power on front ,then you have something wrong with TV.If Remote is problem you can go to dollar store and buy another one with code book to program TV with for 5.00. you may need to replace your STK ICs?
Jan 10, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
Oct 26, 2008 | Televison & Video
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Dec 09, 2006 | Mitsubishi VS-4543 45" TV
Mitsubishi Rear Projection TV
Easy! But you will need the original remote. On the remote is a button called QV for quick veiw. Press that button at the same time with the 9 button. This will open the lock, But it will return when you turn off the set and turn back on again. If you want it to do a normal turn on , once you open the lock you must go into the menu and remove the lock from the set completely. You may be able to find a friend or a store that might let you borrow an original remote? Sorry to be the bearer of poor news my friend. Good Luck
Aug 08, 2006 | Mitsubishi VS-55707 TV
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
