Almost definitely the pump filter is blocked.
Its happened twice on mine. Tilt machine forward to expose filter, undo clips on flexible hoses and remove filter. clean it out and replace. problem solved. about an hours job.
The inlet valve motor might not work properly or it may be always open to sent the water to tub please change the inlet valve motor
If the problem exist please check the main board of machine if you found any spares of board damaged please change the machine board
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
