Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WD440 Does not spin properly. Only 2 years old. All the lights were flashing also the other day. Help!
  • 126 Answers
Check the coalbrushes in the motor. This is a common problem on most frontloaders.
Posted on Jan 24, 2008
Wat does blue light flashing under washine machine wen it goes into spin
sounds like its the moter! when it goes in to spin the carbon brushes makes sparks and would prob do this but it normaly does it when the machine has been working a year aprox depending on use! it should not do this if its new or a month old! if under warrenty i would call them to get it checked as sparks is not good!
Feb 28, 2013 | Hoover AAA160 Front Load Washer
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
The waching machine won't do anything when turn to rinse or wash, it only starts to rotate when turned to spin? the machine is only 2 1/2 years old
Whats the exact brand and model.Is it front load or top load.Is it showing any error code on display or any flashing light error code.Is it draining properly or not draining.Also is it making any kind of noise when turned towards spin mode.------------------- Keep updated with the details.Thanks.Helpmech.
Jan 30, 2011 | Kenmore Kitchen Ranges
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Intermittent flashing of all dashboard lights
Weird,sounds like your battery connections are possibly loose, but
the car wouldn't start properly, or at all, if this was the case. You might just have a loose connection to the dashboard controls?
If you are up to the task, I'd remove the guage console,if you can,and make sure all the connections are tight. Good luck.
Mar 30, 2010 | 2004 Ford Focus
Hotpoint aquarius WML540, HAS JUST STOPED WORKING ITS ONLY OVER 1 YEAR OLD,WILL START ANY WASH BUT JUST STOPS WHEN IT REACHES THE SPIN AND DRAIN AND ALL LIGHTS START TO FLASH VERY FAST CAN YOU HELP.
Could be the pump blocked or not working, check the pump for blockages or wiring faults. For Hotpoint, Creda and Indesit error codes that include flashing lights visit selfix-uk
Mar 20, 2010 | Washing Machines
Hi, many times my wash load does not spin properly and it is still very wet / need to put it on spin cycle again before drying. Also sometimes does not use the liquid fabric softner along with not properly...
Hello. Have you checked the speed settings on the control panel? There are alsways some sort of speed settings on any washing machine these days. It starts from 500rpm, 700, 800 and 1000 rpm. My Fisher machine spins up to 1000 rpm. Surely there must be some settings in your machine. If not, how old is the machine? If it is a cople of years old, you can contact the retailer and find out about it. But if it is several years old, then best if you solve this with a local repairer. Otherwise a new one would do you better, and less worries, too
Sep 23, 2009 | GE Washing Machines
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
Whirlpool Duet's interupted cycle won't restart
unplug, let sit for 2 min, replug and try to put into drain/spin cycle
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
193 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
