Question about Cameras
Kool-aid was spilled on Digital camera
Is a camera worth saving if kool-aid got spilled on my digital camera? It turns on but stays in the "Docked in Port" position. It will let me view pictures that I have taken but will not take new ones. I don't know which one it is on the list because it isn't with me right now so I just selected one. It has 6 megapixels. -Becky
  • 667 Answers
Hi Becky,
The sugary content of Kool-Aid is not real camera friendly. It would appear a short has already been created internally. The tightly packed components of the camera are very difficult to clean effectively.
Posted on Jan 24, 2008
How to cast a spill
My son spilled his kool-aid
Nov 02, 2016 | Cars & Trucks
Will not turn on.battery tested and was fine.
Bad push buttom, or something inside the buttom, like any cola or kool aid between the push buttom.
Try to check if the push power buttom it´s working.
Dec 07, 2015 | Cameras
My daughter spilled kool aid on the buttons of the tv now it wont turn on. what do i do?
unplug it and wash it with alcohol to remove the gum of the Koolaid.
Just wash it and wash it to keep away the gum
Dec 06, 2015 | Emerson Televison & Video
How to clean sunbeam window air conditioner 5000 BTU
To ensure you are achieving absolute BEST energy efficiency, I would strongly encourage you to take the following steps:
1. Unplug your unit, disconnecting the electrical service from the unit.
2. Remove the filters from the front of the unit.
3. In a typical quart spray bottle, add 4 packets of UNSWEETENED Lemon KOOL-AID, fill 1/2 full with water, screw top onto bottle, shake well for 30 seconds, remove top and add water to near the top, screw top onto bottle and shake again to mix it very well.
4. Spray the INDOOR COILS with the above KOOL-AID solution until all of the solution has been used. The CITRUS Acid in the KOOL-AID will penetrate the coils and not only remove unwanted dirt, dust and debris; but it will also clean the bi-metal portions of that coil, making it SHINE.
5. Let the KOOL-AID set on those coils for a MINIMUM of 30 minutes.
6. While the KOOL-AID is doing its job, take the filters that were removed and rinse them under a faucet, ensuring the water is flowing from the back to the front of the filters in order to dislodge and remove as much debris as possible. It is acceptable to now spray the filters with either a solution of 50% water and 50% hydrogen peroxide OR simply spray with any household disinfectant/cleaner such as Lysol or Mr. Clean or similar product. Bump the filters against your hand to remove any additional water or household spray.
7. After at least 30 minutes, take that same spray bottle and fill it with clear water. Spray those coils once more with clear water to flush what ever may have been left within those tiny coils.
8. Add 1 drop of light weight oil to the fan motor and bearing.
9. Re-install the front cover of the unit; and then reinstall the filters.
10. Plug into an electrical outlet.
11. Turn the unit to the COOLING Mode and HI Speed Fan Mode.
Enjoy continued usage of your A/C unit.
This should be performed at least once each year in order achieve the highest EFFICIENCY of your system.
Sep 01, 2014 | Heating & Cooling
Seer ratings
That's an older 10 SEER unit. They are not made any more. The lowest SEER made, to date, is 12.
However, that being said, a 10 SEER, 3-ton unit such as the one you have, it is ONLY going to be as energy efficient as it is equally maintained.
Aug 27, 2014 | Heating & Cooling
Ge window ac not very cold SOME TIMES
Window A/C units are SEALED systems. In order to achieve ICE COLD air from a Window A/C Unit:
Aug 25, 2014 | Heating & Cooling
Air conditioners
Aug 25, 2014 | Carrier 39na40000634 Damper...
I have a Sanyo Vizon DP42647 that was given to me. Everything seems to work great except it looks like red Kool-Aid was poured on the screen. Can it be cleaned or just pitch it
I think it is more than a Kool-Aid stain. likely it was some kind of heat applied to the screen causing physical damage. How does it appear when the screen is white?
Aug 20, 2014 | Sanyo VIZON Multisystem 42" LCD TV 110-220...
When you flush, sometimes it flushes fine, and sometimes the pressure isn't there at all and you need to reflush
Make sure the flapper is holding water in tank. if it is leaking, then when you go to flush there is not enough of water to flush. to check for leaking flapper,take a pack of kool-aid and dump it into tank of toilet. dont flush toilet. let set for 10-15 mins. if the flapper is leaking,the color of kool-aid will show up in bowl. hope this helps.
Sep 28, 2009 | Kohler Toilet - One Piece with Ingenium...
Cameras Logo
75 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
