Question about Polar M32 Heart Rate Monitor Watch
No sound When i changed my battery for my m32 watch it works well but i get no alarm sound or if i go over or under my target heart rate it does not sound?
Make sure the sound is turned on the unit. Press and hold the lower left button for a few seconds and you should see a little Sirus like pic on your watch. If you have that and no sound then you have a problem. Maybe try taking the battery out and reinstalling after a few minutes. If nothing works then your choice would be to send the watch to get repaired or live with it. The heart rate does flash if you are under or over your target rates. Good luck
Posted on Jan 27, 2008
Watches under pressure require sound sensitive spring. If no contact between the back and spring is made there will be no sound. this cound be cos back too high from incorrect placement of rubber seal.Also, if high vacuum, low sound. Try hear if its faint at back of watch. If nothing, and casing is fitting flush with back of watch then send it in -
Posted on Apr 11, 2008
How do I turn off beeps on my ekho E-15 watch
Go into the menu, turn off alarms, beeps and chimes.
Oct 10, 2012 | EKHO E-15 Heart Rate Monitor Watch
Repalced battery and have no display
you had to reset it by pressing all the buttons on the same time.
Jul 09, 2011 | Polar M32 Heart Rate Monitor Watch
I need to replace battery
All you need is to open watch case back, remove the rubber seal and unclip the contact. Take the battery out (memorize polarity: + and -) and buy the same one. Fit new battery in the right way back in watch, fit the contact, place back rubber seal and refit watch case back. Reset the watch. Done.
Feb 25, 2011 | Polar M32 Heart Rate Monitor Watch
I have turned my sound off on my watch and the alarm sound but when I am working out my watch beeps at every heart rate, its annoying I know there is a way to have no sound, I had it that way before but...
Assuming that your limits are set correctly, this is a job for a Polar Authorized service center.
There is most likely a problem with the computer, depending on the age of the watch this will be taken care of under warranty. The link above explains the process.
If you replaced the battery yourself (never recommended) some contaminant could have gotten into the electronics, or the seal is no longer working allowing moisture into the unit. These are highly sensitive electronics and should only be handled through the service centers. The work they do is covered with a warranty and they replace seals and vaccuum pressure the watch to make water tight again, as well as run a diagnostic on the computer.
In the mean time if you don't want to send in you can set the Heart Rate limits - both low and high well above your actual limits and that will stop the beeping, as the beeping while you are working out is an out of limit/ zone alarm.
Nov 19, 2010 | Polar F6 Watch for Women
Is there a store where I can take my Polar M32 for battery replacement?
The only way to find out is to take it to your local jeweler/watch maker and see if they have the tools to do it.
Or contact them at the following link:
http://www.polarusa.com/us-en/support/service?product=&category=Service+Information
Good luck.
Aug 10, 2010 | Polar M32 Heart Rate Monitor Watch
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jun 10, 2009 | Polar M32 Heart Rate Monitor Watch
Where can I get my batteries changed on my watch and transmitter belt. I live near exeter in devon
Here is the link:
http://www.polarelectro.co.uk/uk-en/support
As this is direct link to Polar (UK), I will accept FixYa rating only, even if you will not be able to find what you are looking for.
If you are not happy with that- don't blame me (I'm not the owner of this site) and did my best to find a solution for you.
Not happy-do not rate, please.
Mar 21, 2009 | Polar M32 Heart Rate Monitor Watch
I have a problem changing the battery of my polar HRM watch.
Here is the link:
Jan 24, 2009 | Polar M32 Heart Rate Monitor Watch
Chenge the battery
Response to Wasilij: The belt is sealed, so it can be used while swimming. It's not meant to be opened. They replace the whole thing, instead of replacing the battery. So sorry, not going to work.
May 12, 2008 | Polar M32 Heart Rate Monitor Watch
Changing battery
Hi cobbie,
It is a good idea to get a watch repair guy to change it for you. They have the tools and experience to do a good job and they seldom charge more than $15-20 to do it for you. The watch casing generally needs to be cleaned, and often the gasket replaced to maintain water tightness.
If you live in the US, you can get a mail order service done here on the watch for $19 that also includes watertight testing, and the job done by experts that do them everyday. If you are outside the US, get back to me and I will find someone close to you.
regards
robotek
Polar M32 Heart Rate Monitor Watch Logo
438 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
