Question about Tomtom GO 510 GPS Receiver
Tom Tom Go 510
The unit will not turn on. The charge light is on but no screen.
  • Tom510Tom Mar 17, 2008
    Tom Tom 510 will not turn on even when plugged in. Green charge light works. Reset the unit. This turned the unit on which then worked for part of one day. During use it just turned off not to start again. I will try to reset the unit again and reinstall the software. Sorry I did not get the Garmin.
  • Anonymous Aug 05, 2008
    Charge light is on but unit will not turn on. Forgot how to reset the unit. Talked w/ rep in the past when I had this problem & reset took care of the problem.
    Have had Magellan & Garmin units. Like the Tom Tom until this problem.
Www.batteryship.com
order the battery-comes with instructions and tools
only 21.95
much less than sending it in!!!!!!!!
Laura
Posted on Feb 05, 2008
Try resetting it
Posted on Jan 25, 2008
My tomtom go 510 will not charge in car but ok at home
The Car chargers are generally the defective unit.
I have also faced a similar issue as the spring loaded cigarette lighter was pushing the charger causing it to disconnect.
Jul 31, 2016 | Tomtom GPS
Tom TOM DOESNT CHARGE OR TURN ON.iT WAS FIXED LAST
I must aplologise but this is not tomtom. your concerns would better be served if you were to contact them through the following web site.
TOM TOM
Aug 25, 2009 | Tomtom GO 510 Car GPS Receiver
Tomtom go 510 do disply
Same here and with aftermarket mount. The light comes on but its not really charging. I was acutally able to find a sweet spot basically by pushing it down and to the right slightly (into the base) and held it in place with left hand and put the unit in the upper left part of the windshield, elbo in the window frame and move the unit around until the low batter warning dissappears, then don't move. Theres a specific screen that will tell if its charging or not if you tap the lower right part of the screen after booting up if you can get that far. I forget what it was, I think displays speed and miles to go. (But definatley hold the whole unit down and to the right and hold it for a while so it can charge up a little.) Then try turning on and you should have enough power to tinker with it. I would up putting the tom tom in the upper part of the windshield, then stuffing balled up napkins between the roof and the unit to keep pushing it down.
I also plugged it in the the original computer hook up base to see if the problem was on the winshield one or the tom tom itself. Both chargers do it so I am assuming that its the tom tom itself. I still CANNOT figure out why the charge light could be on and still not charging.
I am going FRD and taking it apart. (Fix Or Destroy) Since they are getting pretty cheap, nothing to loose I guess.
Thanks back to all the posters on this site!!
Feb 23, 2009 | Tomtom GO 510 GPS Receiver
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Tomtom won't turn on
  1. Fully charge the unit
  2. Reset with paperclip at bottom of unit
  3. Hold down Power On for a longer period of time, about 10 sec.
It should start...
Apr 10, 2008 | Tomtom GO 510 GPS Receiver
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
Tom tom go 510 Sat Nav
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 25, 2008 | Tomtom GO 510 GPS Receiver
Power problem
power on while resetting the small hole near the docking connector.
I had this issue and the device powered up after that
Heber
Nov 14, 2007 | Tomtom GO 510 GPS Receiver
Tom tom go 510
There is a reset button (hole) underneath by the plug-in bar. It is real small, you'll need a small paper clip straighten out
Nov 05, 2007 | Tomtom GO 510 GPS Receiver
Tom Tom One
arrange for it to be returned & repaired.
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Nov 05, 2007 | Tomtom One Europe v2 GPS Receiver
GPS Logo
122 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
