Question about Technics RS-TR373 Single Cassette Deck
Technic 1210 decks
Hi
I've recently moved house and brought my decks with me. I've just set them up and one deck is spinning like a washing machine, its way to fast. What could be the problem?
  • 36 Answers
Jamesbillett:
do you know how many motors inside?
i.e. one each for pb/rec, reverse, fwd, or just one motor for all?
it is very likely that one of the pulley rubber loop is broken or hardened in time. so the motor spins by itself instead of gearing up the mechanism.
input me with more for detailed solution.
pc-cook
Posted on Jan 25, 2008
One of my decks sound louder than the other
I'd say the cartridge is getting tired. Swap the head shells with carts and test. Cheers john. Styluscity
Nov 27, 2012 | Technics SL-1210 Turntable
I own a craftsman LT 2000 17 HP it has worked well and as a rule I am pleased however recently I changed my blades and encountered a problem in that the laft bade turns slower than the right the result is...
Hi and welcome to FixYa, I am Kelly.
You assessment of the problem is pretty much on the mark. Here is what you should do to check the bearing.
1. Remove the belt from the suspect deck pulley
2. Reach under and try and teeter the blade by gripping the end of the blade and lifting it up and down. (None allowed but compare it to the good blade) Watch both the under side of the mower deck for movement and the upper side pulley of the mower deck for movement.
3. Spin the blade by hand and feel the blade bearing upper housing as it spins You should NOT feel any rumbles, strange vibration or odd noises as the blade is rotated.
4. Wrap a nylon rope around the drive pulley like a starter recoil tightly, tie it off and try and rotate the blade. Reverse your nylon rope wrapping direction and do this again. If the blade moved and the pulley does not move most likely the shaft key in the blade adapter has sheared or is missing. (You can try this test with the belt on....also vs using a rope. I find that I still have to tie the belt together to keep is from rotating.)
By doing this you are going to identify the problem.
Thanks for choosing FixYa,
Kelly
Apr 13, 2011 | Craftsman Garden
Hi, I have a westwood ride on mower & the 3 bladed 36inch deck has started to whine bearings I think? Are they easy to change? special tools? parts off who? the machine is just 3 years old Thanks JT
I assume you are referring to the deck bearings. The easiest way to replace the blade drive bearings is to remove the deck from the mower. You can then easily remove the blades, clean the deck and be able to easily get to the bolts holding the bearings and pulleys in place. This is normally a straightforward repair and can be accomplished with common hand tools. You will need to purchase the parts from the dealer who sells the mower. Replace all 3 set of bearings. On a 3 year old mower ask yourself why the bearings failed. Are you washing under the deck when the bearings housings are hot? That will cause premature failure. Are you greasing the bearings regularly?
Sep 20, 2009 | Garden
On/off knob, spindle problem
u will have to phone me on this one mate coz it's a big job, but i can defantly help you.i,ve had many a technics in bits & theres a nak.....
TEL:07970306952 Tatty
Aug 02, 2009 | Technics SL-1200MK2 Turntable
Deck fades out when i bring the second deck in (records I mean)
are you running phono pre amps ? are you running pre amps to each deck or one for both decks , if you are running pre amps maybe the power supply is not sufficient to run two decks anymore [ possibly damaged ] but it sounds like a power delivery failure to me . hope this helps
May 24, 2009 | Technics SL-1210 Turntable
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
Deck speed up to uncredible speed and wont stop
You both have issues with your drive circuits. There is no easy fix for this. You will have to take it to a repair center to have them serviced.
There are 4 main Integrated Circuits that control the speed/drive and any one or all may have gone bad. We are seeing this alot with these units now.
Wish I could be of more help.
- OPTiC
The 1200s Expert
www.1200s.com
www.repairnyc.com
DJ Pro Audio
Aug 23, 2008 | Technics SL-1210 Turntable
Technic 1210 will not turn on
im in the same boat same prob with mine not happy
Dec 26, 2007 | Technics SL-1210 Turntable
Kenmore top loading washer 70 series
Hi I have a kenmore that is moving when it spins....some water left when spin is completed. We recently moved the machine to clearn behind it and this issue started. movement is about an inch per cycle.....can you help? thankse ,pde 22422
Dec 10, 2007 | Kenmore 22422 Top Load Washer
Technics RS-TR373 Single Cassette Deck Logo
62 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
