Question about Toshiba 32A33 32" TV
Toshiba CRT Hi - I have a 5 year old 36" Toshiba CRT wired up with surround sound. Not knowing what i was doing tried wiring my hi fi to the same speakers !! I seem to be hearing the laughs now. Turning up the sound on the hi fi, I heard a 'crack' noise from the tv and a 'electrical' smell. Now I cant get the surround sound from my tv. Have i blown the tv amplifier ? If so can i get a replacement and at what sort of cost ? Keith.
    Genius:
  • 1,139 Answers
Hello krs001,
At best you have brunt out the audio power amplifier of your TV. At worst you have also taken out you power supply that is technically connected to every section in your TV. This right now, is not about replacing a part, it is about finding all of the damage that was done and repairing those items (you notice I said items). I say this because if you caught a break on this you will only have one damaged part and that is the final Audio amplification stage, but I don't believe in breaks or in luck so assume the worst. I would suggest that you take the TV to a repair shop for an estimate, if the estimate is over what you expect, get a new TV and try to repair this one as you look at your new TV. Its good for practice.
I hope this helps, Thank you, Shuttle83
Posted on Jan 24, 2008
  • 2,130 Answers
Hi Keith,
Your Hi-Fi is designed to produce many watts of audio power. It would be a fair assumption that you took out the output section of the audio amplifier of the CRT.
The best way to accomplish sharing the speakers between the CRT and Hi-Fi would have been to use a switch box, that way both audio sources would be isolated from each other and whatever source was not being used would be put into a dummy load.
You need to find the Part number of the damaged part. If you open the CRT (power unplugged) you will probably be able to find it with your nose, since it was damaged and burned up.
Call MCM Electronics with the part number and see if they can cross reference a replacement for you.
http://www.mcmelectronics.com/
1-800-543-4330
Good Luck,
- Jim
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Beko nr 15lb450s no sound
audio chep most be replaced or try to diag. from speaker wire test it with the tester if given power. if not try to check all capasito and resitor if given the right voltage.
Jul 01, 2012 | Beko Televison & Video
Hi.. I bought a used vehicle(2010 Ford F 150) which has a farenheit dvd-36 system I tried to play the dvd and the monitor, wire, remote....everything is working good. but, the only problem is that the
OK....Pull the dvd player out. Look to see if it has speaker wires coming off the back. If not, does it have rca plugs???? (red and white). if so then you are gonna need an amplifier to get sound. If it DOES hve speaker wires, chec to see if they are hooked up to the speakers in the vehicle.
Mar 13, 2012 | Farenheit DVD-36 Car DVD Player
I bought a 3 year old Sony FD Trinitron WEGA KV SW29M50 29 and it did not come with a manual question thereare 5 jacks above the video jacks what are they for i have surround sound speakers how do...
The inputs you refer to should be colored as follows.
Red
Blue
Green
Red
White
(not necessarily in this order)
These are what are called Component Video inputs and is one of the way that HD capable equipment connect to your television. It will not get true HD picture but this input will provide you with a crisper clearer picture.
Good Luck and Happy New Year.....
Jan 03, 2010 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
AVR 120 5.1 -dolby surround sound & logic 7.
The problem is fixed...
and every thing sounds great !!
Thanks for the premium assistance to help solve my problem...
Pierre
Dec 07, 2008 | Harman Kardon AVR 120 Receiver
Please help
I don't think you can do that if your system was not designed for the additional speakers and a subwoofer. Your system is not a Home Theater surround sound system.
You could add the additional speakers by splicing the speaker wires but I wouldn't recommend it and it would not work like a true surround sound system.
Nov 20, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
No Sound
have you checked the switch at the back of the set (very small) that is marked internal or external speakers
Nov 10, 2007 | Proscan PS36600 36" TV
RCA Model f36665 Guide series 36" TV
Who said it cannot be fixed? You can try and hook an external speaker to wires and test for sound. Maybe audio outs have sound?
Oct 29, 2007 | RCA F36645 TV
No surround sound with dolby
I have the same system, the ports for surround speakers only seem to work with the actual surround speakers I bought mine with. I did try to change them but found a sound issue. Looking to buy a new 5 cd changer as mine was damaged during our recent move. Looking to buy model number DX-Z9400M
May 19, 2007 | Aiwa AV-D57 Receiver
Toshiba 32A33 32" TV Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
