Question about Acer Aspire 5500 5570-2609 Laptop
Runpath i,m new to the laptop scene i loaded u torrent to my laptop and new when i start it up it says runpath error 75 . works ok but i want to get rid of it......please help i,m a complete nugget
  • dazcabs Jan 25, 2008
    thanks for the quick reply but already done that with no success
    Sergeant:
  • 226 Answers
Go to add remove programs located at control panel. remove u torrent. restart your computer. thats it.
Posted on Jan 24, 2008
I have an acer one 8.9" laptop. I down loaded a torrent that stopped and started a few times and said I had a bad hard disk. Now I cant get past the acer start up screen. Ive with the external disk drive...
Try re-starting in safe mode, press F8 as its booting, assuming all goes well choose safe mode, this loads a windows shell. Using Accessories - System tools - System restore - Restore to a point prior to your problemsn.
Sep 21, 2010 | Acer Computers & Internet
Received a blue crash screen, Alt,F10 for erecovery, showed copying files, then tried to reboot and shut down without completing reboot. Now when try to start, showes windows small window and moving dots...
You can use a torrent site like isoHUNT, to download a copy of the Acer OEM vista disc, this is a little illegal, but if you use your own Windows key from your COA sticker, it should register and activate ok.
You may have to download your drivers seperatly from from ACER.
You will need a torrent client like UTorrent, and the download could take a day or so
Aug 27, 2010 | Acer Aspire 5100 Notebook
Xbox 360 is making grinding noises
H there,
I have made a tutorial for all those people having problems with their discs, such as;
•Dirty Disc Errors
•Games crashing half way through , due to reading problems
•Discs sometimes loading, and sometimes not being recognised
•the classic "OPEN TRAY" problem
•and also glitching FMV or slow loading games (some games are just slow, its normal so be patient)
Please remember to test the disc on another console to ensure you have burnt it correctly. This is so you dont go and adjust the pot when its actually ok.
Download from the link below..
http://rapidshare.de/files/22184766/XBOX_3...y_Moda.pdf.html
X-Scene mirror:
http://dwl.xbox-scene.com/tutorial/XBOX_36...1.0_by_Moda.pdf
Hope it works.
Regards,
Anirban Mazumdar
May 22, 2010 | Microsoft Xbox Console
Lost my box with my key and want to load game on new laptop i have my receipt of purchase - would that help
As a ahem.. work around.. you could download and use this as you do own it so using this should be OK.. http://thepiratebay.org/torrent/3695899/PC_Pac_Man_World_3_(c)_Namco_Rip_3_(ToeD) get uutorrent if you don't have it download from www.uTorrent.com. Simply install run accept defaults, and get the torrent by double clicking on the name in PB. 1.: Unrar archive!2.: double click > ToeD.exe < to install the game 3.: Launch Game with > pac-man world 3.exe < (Gamefolder) 4.: enjoy! use trainer if you want!
Feb 06, 2010 | Namco Pac-Man World 3 for Windows
Stuck key. No opening of Windows
ok hit the f1 key inter the bios and in bios look to the bottom of the screen or upper left corner . you will see load default. ok load the default then save and exit.
Nov 12, 2009 | IBM ThinkPad R50e Notebook
Runndll 32 error.how to partition the hard disk
hi,
whenever you repartition a drive all the data is lost in those partitions
a quick way to get rid of rundll32 error is to do a system restore using safe mode, which will restore your system configuration to a date when your system was working fine without rundll32 error, it is possible if you remember the date on which your system was working fine
when the system starts at the blue dell logo start tapping the F8 key and when it gives you the option to use safe mode select it and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
here it will show you in bold the dates to which you can restore your system back to, select the date and continue, but restoring a system back in date will make you loose any new settings done to the system or any new software installed to the system.
If you think the above info was helpfull please do rate me
Regards
Ltoso
Jul 07, 2009 | Dell Inspiron 1525 Laptop
Run DLL error loading..........
I had that problem to , and i instaled service pack 2 and  3 and all was ok after that.
Jan 13, 2009 | Toshiba Computers & Internet
Gate way ip
Who is your ISP? Comcast, and several other ISPs (ATT, for example) have started "delaying" torrent traffic. What they are actually doing is inserting a RST packet, causing the connection to reset, and the torrent then needs to start over. This is the likely reason your torrents are taking so long.
If you'd like to ensure that the router is not at fault, you can plug a cable from the laptop's Network port directly into the modem (you'll need to take the router out of the loop), then cycle the power to the modem (so it will see the laptop instead of the router), and then try your torrents. If everything then works as you would expect, the router is the problem. I think you'll see the same problem, and if so, it proves the router is not at fault.
Feb 22, 2008 | Belkin (F5D7230-4) Router (587009)
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
