Question about Sony KV-27S65 27" TV
Panasonic tv help
Panasonic tv model no: ct-13r38sg burn a resistor no: 527 and transistor no: q 503 on circuit board need your assistance.
My tv screen just turned brown. sound and everything else works fine?????
Panosonic HD tv
Posted on Nov 13, 2008
Im having a problem with my Panasonic crt tv model # ct-25g7f. When power button is pressed it turns on and then turns off by itself if pressed on occasion after a while it turns on and picture is...
My question on your problems;
Power button of your TV or Remote pwr button?
Anyway, 1. If TV power button - the culprit is in your power button switch, lose contact - defective. Replace with spare.
2. If you're referring to remote power button - It's a signed of 'COLD SOLDER' joint where galvanic action occur in every electronic terminal leads soldered by LEAD, (terminal lead material is copper & solder material is lead = Corrosion due to galvanic action), at POWER SUPPLY CKT section. How to check a cold solder joint - Remove power PCB to access the soldered components and look for discoloration on terminal lead tip, if you found one try to wiggle the component, say Capacitors, Transistor, Resistor or Transformer it will easily detached from solder.
3. Other technique - Remove back cover of your TV, switch on power button then try to wiggle big component like capacitor, resistor power transistor if cause by cold solder the tv will on & off locate and fix. Please refer to photos. 25275605-g2bij12ihmeeyzuixp5ga03n-5-0.jpg 25275605-g2bij12ihmeeyzuixp5ga03n-5-2.jpg
Nov 08, 2014 | Televison & Video
Panasonic color TV model CT-32G9J won't turn on.
been a long time since fixed an crt tv. but if you have a stand by light the problem on this model is the control chip if remember right it sits on the left side near to the front. think its an 8 pin chip. these just go and it will not turn on. these chips are easy to get hold of and are cheap. you just need to remove it and replace with a new one. and the tv will work again. its not on the power board but is controlling the power start up. if there is no stand by light its a longer problem to solve. it could be a number of problems. would need to know if any problems happened before the tv did not turn on.
Jan 15, 2014 | Televison & Video
Tv going on to standby but not going on
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ............... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact panasonic service centre.........
Apr 20, 2011 | Panasonic CT-36SX31 36" TV
How to dismount ENG36604G tuner from CT-27D11 27" Panasonic TV
With difficulty.
Soldered to board.
Only qualified techie can do it.
Oct 05, 2017 | Panasonic CT-27D11 27" TV
Panasonic TV - no picture, but sound is ok
resolder flyback transformer contacts on the board, if doesn't help, replace flyback and horizontal output transistor
Oct 06, 2009 | Panasonic Televison & Video
Need code to mate ONE for ALL to tv
if you goto the remote's manufacturers web site you will get the code from there
May 08, 2009 | Televison & Video
Panasonic color tv model ct-13r38sg 13"
verticle amplifier is not working on your tv
take it to a shop if you dont know.
verticle IC BE CHECKED.
AND ELETROLITIC CAPACITOR feeding verticle scan coil.
Jun 01, 2008 | Sony KV-27S65 27" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Panasonic CT-27HL-14J Chaisis BP416
Do you know how to work on solid state electronics? if not then Im sorry to say you will need to get the assistance of a local tech who is experienced. As these sets are solid state and there are no user servicable parts inside. Good Luck
Oct 16, 2006 | Panasonic CT-27HL14 27" TV
Screen adjustment
Something is going bad in the horizontal deflection circuit,you should not have to adjust at all,if this part fails (possibly a capacitor)all the way is goin to take the output transistor and a fuse ,I suggest you call for assistance now before it gets worst.As for the remote you can find it in Google.com,just put the model number of the tv and the word remote and all the information you need will show up.If you are familiar with tv service you want to take a look for overheated components close to the flyback but if you are not too familiar be safe and ask for help.
Oct 06, 2006 | Panasonic CT-36D30 TV
Sony KV-27S65 27" TV Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
