Question about Dell 1700 Laser Printer
I have a dell 1700 laser load paper lite and ont print from tray
I have a dell 1700 laser that i received from a friend who said it needed toner so i bought the toner and changed it no problem
the problem is the printer seems to be stuck wanting to print from the side manual feed and not the tray. The tray is full of paper however it will not use the paper from the tray.
is there an internal setting to tell it to use the paper tray and not manual
  • Anonymous Mar 13, 2014
    no printing paper
    no printing paper
    Genius:
  • 3,587 Answers
Sure..it's in the printer control panel, under paper source. Open that up, and you'l lmost likely find that it's on a default. Also, do a print test page under admin, prior to doing any print jobs.
http://www.kauaikeepsakes.com/computerguy/
has an option for a Free demo of a Shared Screen session.
Posted on Feb 03, 2008
6ya staff
SOURCE:
How do I clean the rollers on dell 1720?
First of all dirty rollers are not the cause of your problem as long as the printer is picking up the paper.
Black marks or streaks on a DELL 1700 series printer are usually caused by the drum assembly which, in this model, is separate from the toner cartridge. There is no repair, you need to replace the drum assembly and perform the drum reset procedure. In very rare cases a buildup of residual toner on the fuser can cause marks as well, but I have never seen this on a DELL printer.
To replace the drum:
1. After removing the paper tray, open the front of the printer.
2. Remove the toner cartridge by pushing down on the black release tab and pulling the toner up and out of the printer.
3. Pull the drum assembly straight out of the printer using the blue plastic handle.
4. Carefully unpack the new assembly and install in the printer. Be careful not to touch the photo-sensitive roller underneath.
5. Reinstall the toner cartridge, close the printer and insert the paper tray.
6. Perform the drum reset procedure exactly as follows:
power off and open front door hold down the continue button as you power on printer leaving front door open when error light comes on release continue and close front door. toner low, load paper, ready, and continue will all be lit. press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change when just toner low is lit, press and hold continue button until lights cycle up and down in sequence. release continue.. toner low will be lit again turn printer off, wait 10 secs or so and then back on press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Aug 10, 2014 | Dell 1720dn Laser Printer
PRINTER IS PRINTING OUT PAGES WITH DARK SMUDGES FROM ROLLER. DELL LASER PRINTER 1700.
toner spill on the paper path. this occurs mainly due to 0verfilled toner cartridges ( refills) use damp cloth or metho damped cloth to clean the rollers in the paper path.
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | Dell 1700n Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Dell 1700 prints a page with parameters before every print job
Probably some sort of software glitch, I'd say. First thing to try is re-installing the software with the latest version. Here's the link to download if you need it:
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cabsdt1&l=en&s=bsd&ServiceTag=&SystemID=PRN_LSR_1700N&os=WW1&osl=en&catid=&impid=
May 01, 2009 | Dell 1700n Laser Printer
Dell 1700 only printing to envelope feeder
make sure that the manual feed tray is not set as default make sure you main tray is
Apr 30, 2009 | Dell 1700 Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Dell 1700 printer will not print
Hi albrecht,
i think u might have used ur printer without paper often . unplug the printer from system and switch it off.Replug it again on the system ant switch it on and see. Even then if it is not printing uninstall the drivers for printers and reinstall again and print.
Mar 04, 2009 | Dell 1700 Laser Printer
Call Dell. the 1700 has special reset instructions for resetting the drum count.
Feb 24, 2009 | Dell Office Equipment & Supplies
Dell Laser printer 1700
pickup rollers bad, you can try to clean them with rubber cleaner but it's best to have the rollers replaced.
Jan 22, 2008 | Laser 22 ppm Mono Printer
Dell 1700 Laser Printer Logo
174 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
