Blurred/double vision Samsung HDTV 1080i projection
The screen has blurred/double vision and it looks like it is the color red that is off. Also at the top and bottom on the screen there is about a 2 inch wide half moon that is black. It is like the screen will not adjust properly and neither will the colors. I could care less about the HDTV stuff I just want the picture to look right
  • 1 more comment
  • theedwards Feb 03, 2008
    I am having the same issue....one day the TV is fine then the next it turns into blurred/double vision with a large half moon at the top of the screen. I dont know anything about fixing this..is this an easy thing to fix..i have someone who can solder. Where can I locate these parts. Please help...this is for the Samsung HDTV 1080i 46in tv.
    Thx
  • snoopy1225 Feb 29, 2008
    I have a Samsung PCL545R 54" with similar problems. The screen displays all three colors slightly offset (shifted) from each other, which gives the a 'blurry' picture. Also has what appears to be a convergence problems, with half-moons on both the top and bottom of the screen. The colors also show up while watching older b&w tv shows. I have tried the various settings to try to adjust the color and picture with no luck. This condition basically happened overnight - was working fine and than two days ago, the colors and convergence issues started.
    Is the fix for this the same as mentioned in the response - the two IC's and possible resistors?
    Thanks
  • colets699 Mar 21, 2009
    my samsung hcn4226w projection tv has blurred/double vision as well as the top and bottom picture is curving inward. also the color is off mainly the red
  • 8,617 Answers
Your convergence ICs are bad and maybe the two resistors right next to them. This is an easy and inexpensive repair if you can solder. A repair shop will run about 400.00 The parts are readily available for about 10.00 each you will need two ICs STKXXX-XXX
Look inside your set for a large aluminum heat sink that's where hey are located they will have an STK number like above stamped on them. Those are the part numbers. Let me know what type of TV and model number you have and I can help you locate the proper parts.
Posted on Jan 24, 2008
6ya staff
SOURCE:
Red color, lines doubled . doubled vision. blurred vision
replace the convergence ICs and check the low ohm resistors also.
Jun 30, 2010 | Televison & Video
Hello tv has warped bottom and top screen on a rear projector samsung and blurred vision with red,green blue colurs not aligned tried to tune to no avail Samsung rear projector tantus sp42w4/42w5
The colors tell me of a convergence IC issue, warped bottom and top tell of another.
see this page on reparing the convergence problem yourself
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
also compair the before and after pictures to see if this is the other problem your having.
Then you have another fault, which im not completely sure of right now. I will look into it.
Oct 27, 2008 | Televison & Video
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Televison & Video
Double vision
If you are printing color and you have color blurring like streaks. it mean the registration of the colors are off. Usually using the internal cleaning function from the panel will clear this up. You should restart the copier as well. If it continues check all the feed rollers.
Feb 12, 2009 | Canon imageRUNNER C3220 Color Copier
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Double- Vision
More than likely your akai has defective stk392-040 Convergence chips . it also may have open resistors generally 3.9 ohm flame proff. this board is attached to the top left looking from the back of the set it is screwed on by 1 screw black in the center . after installation this will probably half to be converged dinamically. which means you will half to get to the grid this is done by using the remote press mute 183 quicly to enter numbers on thew remote 2 to adjust red 4 to adjust blue horizonta 6 to adjustred vertical and 8 to adjust red vertical using center button to go up and down
Feb 20, 2008 | Akai PT4298HD Rear Projection Television
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
851 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
