Question about HP Officejet 4215v All-in-One Printer
The clock reads 10:30 am when it is 9:00 am how do i reset it
  • 434 Answers
Page 60 in your manual.
You can set the date and time from the front panel:
1) Press <Setup>
2) Press 3, then 1 - This selects Basic Fax Setup, then selects Date and Time
3) Enter the month, day, and year (last two digits only) by pressing the appropriate number on the keypad. Depending on your country/region
setting, you might enter the date in a different order.
The time prompt appears after you enter the last digit of the date
4) Enter the hours and minutes - The AM/PM prompt appears after the last digit of the time is entered if your time is displayed in the 12-hour format
5) If prompted, press 1 for AM or 2 for PM
The new date and time settings appear on the front panel display.
Posted on Dec 22, 2009
SOURCE:
How do I reset the time on my HHScott Inc Atomic Clock ?
An atomic clock should set or reset automatically. That's what an atomic clock does. Right now my clock reads 1:35 and the computer read 1:37. Go figure : - )
Nov 21, 2016 | Home
How to reset a Seth thomas weather station wall clock
what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
How do i reset my universal techtronics radio clock to the correct time. I've been playing with it and it reads 12:00 now
Try taking the battery out for a full minute or two, then push the button on the back in your timezone. It should reset.
Mar 14, 2010 | SkyScan 86709 Atomic Wall Clock
The time is no longer accurate, it reads 330:35 eastern time right now! I have tried resetting it but to no avail?
REmove the batteries and power for a few minutes. Then reconnect. It may take it a day to re-sync with the NBS standard clock.
Sep 08, 2009 | Oregon Scientific OR-RM313PA ExactSet...
Remote that gives outside temp does not work put in new batteries, still does not work!
Pull the batteries out of the clock, wait a minute, and then put them back in. That will reset the link between the two. The temperature should be OK in just a few minutes. The clock will read the wrong time and date until it resets during the night. The next day, all will be well.
Apr 20, 2009 | La Crosse Radio Controlled Atomic Clock
2003 MB E320 Sedan - how do you change the time on the clock?
kavtrom to reset the clock you use the instrument cluster by navigating the steering wheel multi function keys untill cluster states settings-after you have set the time while the instrument cluster multi function screen is still at the clock settings you have to press the the reset button/dimmer knob on left side of instrument cluster and the clock will go backwards until 9-10 oclock and then will forward itself to the correct time
Mar 28, 2009 | 2003 Mercedes-Benz E-Class
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
Sep 09, 2008 | Sharper Image SI686 Clock Radio
Emerson research alarm clock
Sorry it took so long to give you a reply to your question. The problem you are having the resetting the Clock's function is covered in the owners manual of the product. I am giving you a web link page, that will take you to the Emerson Customer Support main index page for owners manuals. Here you will be able to find your make and model of Clock/Radio. Just open the page and you will be able to make the adjustments by reading the instructions from the owner's manual.[http://www.emersonradio.com/owners] Copy this link and paste it into the address bar of your web browser. You will need a pdf reader and writer to read the manual and make a copy for your use. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Mar 10, 2008 | Emerson Smartset Clock Radio
HP Officejet 4215v All-in-One Printer Logo
140 people viewed this question
Clive
Clive
Thomas F. Schneider
