Question about Brother MFC-8460N All-In-One Printer
Toner Error We put a brand new drum unit and toner catridge and reinstalled the drum unit several times after reseting the drum counter. What do we do from here since the error is still occuring?
  • 7 more comments
  • lasvistas Jan 24, 2008
    we are receiving a toner error, a new toner and drum ahs been installed and it is still stating toner error
    we have tried to reset this and still having the error.
    Any other suggestions ?
  • scary mary Feb 19, 2008
    we also keep getting the toner error after installing new drum and toner cartridge
  • barry53 Mar 16, 2008
    We have been playing with this for a day and have tried 3 cartridges. Time to give up and NEVER use a brother again
    bsolomon_us@yahoo.com
  • Jillybean037 Apr 01, 2008
    I have installed a new drum and toner cartridge and I am still receiving the Toner Error.
  • Anonymous Apr 14, 2008
    have the same issue as of April 14, 2008. Any solutions?
  • Anonymous May 07, 2008
    toner error - drum near end - new cartridge
  • rookieit Jun 13, 2008
    Toner life end error is displaying. There is still toner in the cartridge but I tried changing the toner anyway, rebooting, and cleaning the corona wire with the blue tab but none of these has worked.
  • fridayharbor Jan 28, 2009
    I am having the same problem-"toner error" is displayed on the screen. I have inserted a new toner cartridge. That didn't work. My boss looked at when he was in town. He couldn't fix it-said to order a new drum unit. I did that and ordered another new toner cartridge. Have adjusted the corona wire. I don't have the little black tab inside that they say to move around. I think this machine is just defective! Oh, it is refurbished. Can't return it. What to do!?
    Scholar:
  • 78 Answers
It's possible that the toner has not been reset due to the fact that you changed the drum at the same time. There is a cover on the left hand side of the toner covering some gears. Remove this (one screw) and wind the toner reset gear (white one by memory) back and refit the cover and put the toner back in the machine. It may take you a few to get it in the right spot but that will reset your toner count and get rid of the error.
Posted on Jan 24, 2008
  • Clint Bowden
    Clint Bowden Jan 25, 2008
    My mistake. I have had a look at one in the workshop, the gear is black one at the front. If this dosen't work where the toner goes into the machine there will be a black switch (toner reset switch). It should be towards the front of the machine. Push and see if come back freely. You can lubricate with a very little dry type lubricant (dry gluide is good it comes in a green can). If it dosen't spring back at all the spring has fallen of the sensor. After you have done you repair to the arm you will need to repeat the process with the gear. If the spring has fallen off or the sensor has failed you will have to take it in for repair.
You guys were right about the plastic peace! after taking off the outside panel and locating the plastic piece I discovered it had a broker piece in it! I then removed the circut board and discovered that there is a plastic piece on the lower right side on the back of the circut board. Anyway The Final solution here is to fill that small part on the back of the circut board with plastic or paper folded up enough to seperate the legs on the back piece and block them from seeing each other.
I think it is a infared sensor that is the ultimate problem...Any way it worked for me. and I thank you all for pointing me in the right direction++++++++
Posted on Dec 18, 2009
Bowdo is exactly right. I just had this problem this morning and the solution is a crappy little spring attached to a black piece of plastic on the inside left of where you install the toner/drum.
The solution is easy and takes about 5 mins, but does require a screwdriver. Why Brother wont walk you through this on the phone I have no clue. Actually, I suspect the spring mechanism is only there to prevent use of non-brother toner and drums since thats where they make their money... but another matter entirely.
To fix it, you need to take off the left hand gray plastic exterior cover. It is a little hard to find the two screws that hold it on. One is behind the flip down cover on the back and the other is behind the pull down gray plastic corner shaped cover on the front (with the button) that you use to load the toner/drum.
Unscrew the screws and pull off the left hand cover. If you also take out the drum/toner cartridge you can touch the spring with black plastic on the inside left and simultaneously see it rotate from the outside left. The spring is actually a piece of wire that snaps the black plastic back (very poorly). The purpose of the spring/plastic part is to engage something that looks like a green circuit board on the outside left (you can only see if the left cover is off). I have had two problems with this spring. One it can come off entirely which requires some tweezers to reattach it correctly. Two it can fail to rotate all the way so that engages the green circuit board. Just rotate it all the way until it "fills a gap" in the circuit. You cant test it by putting the drum/cartridge back in. Thats when the error went away for me.
Basically I think this is a great machine with really, really, really crappy part that causes all kinds of problems. In fact, seems like there ought to be a workaround so that you can disable the spring and have the circuit contacted all the time. Again, I think this is purposely done (poorly and after the intital design) to make people use Brother cartridges.
Hopefully this helps. I am not a tech wizard and I fixed it myself without really knowing what was wrong, so dont waste money on their "authorized repair." Just do it yourself and get back up an running.
Posted on Apr 14, 2008
  • 27 Answers
Somebody tried to install the toner without the drum and pushed the same black plastic flipper arm off its shaft. I pushed it back on from the outside.
Posted on Apr 21, 2008
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
6.Press Options.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
Model MFC 8480 DN is giving a drum error message. HELP! Is there an online users manual available?
Yes, the manual is available from Brother. See http://www.brother-usa.com/manuals/default.aspx?ProductID=mfc8480dn&ProductGroupID=5 and then look at the results for all of the manuals. The direct link to the User's Guide is http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_8480DN_8680DN_8690DW_8890DW_EN_4865.PDF .
A drum error could mean that the corona wire on the drum needs cleaning or that the drum unit needs to be replaced. Make sure that the unit has cooled down before doing any maintanence on the drum unit. To clean the corona wire, turn off the machine and unplug all of the cables from the printer (telephone cord first, power last). Then open the front cover and pull out the drum and toner unit. Move the blue tab back and forth (right to left and left to right) several times. Leave the tab in the home position (aligning the triangle on the tab with that on the unit) when done. Then reinstall the drum and toner unit. Close the cover and reconnect the cables before turning the unit back on.
If you need to replace the drum unit, order DR-20. For changing the drum follow the above steps through removing the drum and toner unit. Then remove the toner from the drum (make sure not to spill the toner) by pushing down on the blue lever. Then put the toner cartridge into the new drum (the blue lever should lift into place and you should hear the cartridge snap into place). To reset the drum counter, do not close the front cover. Leave it open then connect the cables and turn on the unit. Press Clear/Back and then press 1. Close the cover when you see Accepted.
I hope this helps.
Sep 21, 2011 | Brother MFC-8480DN All-In-One Laser...
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
Hope this helps!
Vikroks
Mar 23, 2011 | Brother IntelliFax-2820 Laser Fax
Brother 5250DN Printer Toner light
Try resetting the toner counter manually;  * Turn off the printer and open the front cover * Press and hold the Go-button down * Turn on the machine while still holding button down, when all three LEDs are lit, release Go-button * Press the Go-button twice, and all three LEDs should be lit again. * Press the Go-button five times (six times if you have the High Yield toner) * Close the front cover and the toner counter should be resetted.
Jun 02, 2009 | Brother HL 5250DN Laser Printer
Brother 8460n - toner error
Hi, This worked for us:
The message "Toner Error" is usually caused by the drum and/or toner
cartridge not being installed properly or if the machine does not
recognize the toner. To clear this message, follow the steps listed
below:
1. Verify you are using Genuine Brother Cartridges. Brother strongly
recommends that you do not refill the toner cartridges provided with
your machine. We also strongly recommend that you continue to use only
Genuine Brother Brand replacement toner cartridges. Use or attempted use
of potentially incompatible tone cartridges in the Brother machine may cause damage to the machine and/or may result in
unsatisfactory print quality. Our warranty coverage does not apply to
any problem that is caused by the use of unauthorized third party toner
and/or cartridges. To protect your investment and obtain premium
performance from the Brother machine, we strongly recommend the use of
Genuine Brother Supplies.
2. Make sure that you are using the correct drum and toner cartridge(s)
for your machine. The part numbers for your model are as follows:
NOTE: Some cartridges can look EXACTLY the same among different models
and will fit the machine even if they are not designed for use in that
model. Verify the part number before using the cartridge(s).
TN550: Toner cartridge (standard)
TN580: Toner cartridge (high yield)
DR520 = Drum unitt.
3. Make sure that the cartridge is not damaged. Remove the toner
cartridge by following the steps listed below:
a. Press the cover release button and then open the front cover.
b. Remove the old drum unit and toner cartridge assembly. Place it on a
drop cloth or disposable paper to avoid scattering toner.
NOTE: Be careful not to spill the toner. If toner gets on your
clothes or hands, wipe or wash it off immediately with cold water.
c. Hold down the blue lock lever on the right and pull the toner
cartridge out of the drum unit.
d. Look at the toner cartridge and see if any parts or pieces appear to
be broken or missing, if so, the cartridge may be defective and should
be replaced.
4. If the toner cartridge is not damaged, reinstall it into the drum
unit. If it was damaged, use a new toner cartridge and reinstall it into
the drum unit.
5. Reset the drum/toner unit into the machine.
6. Close the front cover.
7. If the message "Toner Error' continues to appear on the display
unplug the machine from the wall outlet.
8. Open the front cover and remove the drum and toner assembly.
9. Look inside where the drum was. On the left side wall, look for a
small, black plastic lever/actuator. A flashlight may help see it.
10. Using the palm of your hand, slide it along the left wall in and
out a few times as this may free up the actuator/lever in case it is
stuck. The actuator/lever is spring loaded and needs to move back and
spring forward to operate correctly.
If the lever does not move, spring back or is missing and your machine
is within warranty, you can locate a Brother Authorized Service Center
(ASC) in your area or contact Brother Customer Service by calling
1-877-Brother (1-877-276-8437) Monday through Friday, excluding
holidays. If the machine is out of warranty, you can locate a Brother
Authorized Service Center using the information listed above.
If the lever moves freely and springs back to its original position
continue to Step 11.
11. Reinstall the drum and toner assembly, close the front cover and
plug the machine in.
Aug 12, 2008 | Brother MFC-8460N Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
HELP! Brother MFC-8460 "Toner Life End" won't clear
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Dec 20, 2007 | Brother MFC-8460N Laser Printer
Brother MFC-8460N All-In-One Printer Logo
595 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
