Question about Casio EXILIM Card EX-S770 Digital Camera
Camera won't turn on
Had camera 1 year and worked perfectly. Suddenly will not turn on, battery is in correctly, is fully charged (on wall charger) and has not been dropped.
If when you press the power button the little green light on the right blinks it indicates that your circuit board is still ok. It would most likely be a bad lens unit. If you press the power button and the little green light does not blink you have a bad circuit board and it needs to be replaced.
Posted on Apr 06, 2008
2 Suggested Answers
SOURCE: camera won't turn on
Hey I have the same problem. But I do see an Image on the cam is very dark but the image is there. You said that I have to ge it serviced. Where could I take here In NYC?
Posted on May 09, 2008
My samsung pl200 won't turn on, battery is fully charged I even tried an extra one still not working... ????
Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Aug 16, 2016 | Samsung Cameras
Camcorder not working without charger plugged in.
hi if you have the charger plugged in the camera the you have power to work it, if you unplug the charger and it dose not work, the I think the battery is not charged fully or it is no good after being left to long, check to see if the battery is charged. I hope this helps you, please let me know.
Mar 30, 2014 | Sony DCR-DVD602E DVD Camcorder
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Kodak easyshare won't work unless plugged into charger
Hello Pam, You have either a faulty contact for the battery or your battery is suffering from age. After time these camera batteries lose their capacity. Try a new fully charged battery.
Best Regards, Russell
Jan 11, 2013 | Kodak EASYSHARE M340 Digital Camera
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Nikon Coolpix S8100 battery won't charge
I have had mine for over 3 years and this just started happening. I bought a new battery and it seemed to fix the problem for about a week but is doing it again. It seems like it won't fully charge now like it formerly did!
Apr 24, 2012 | Nikon Coolpix S8100 Black Digital...
I have a Canon G5 and am on my third set of rechargeable batteries (I bought an extra Canon rechargeable battery when I purchased the camera and then 2 Canon brand replacement batteries when the first 2...
Thank you for such a detailed description, wishing others would take your lead. To the problem camera designated batteries (other then AA rechargeable) have always been a bit of a sore spot for me because the user is compelled to purchase a specific battery. As much as I prefer the name brand accessories for the camera there come a point where you just gotta venture forth with third party accessories. There is nothing wrong with using an "off" brand in fact what I've found is that is some cases they are a better battery. Again back to the problem. I grasping thoughts on how to word this but, here goes. As much as the manufactures would like you to believe that these batteries do not form a memory they do. Also the battery can trick you into thinking it's fully charged when in fact even though the charge light is saying completed it's only got about 1/3 charge. I've worked with Canon's BP 511 and now the "new" BP 511A for many years The BP511A or equivalent is the better battery. What needs to be done is to drain those batteries down until they stop, let it cool don't take it from the camera to the charger. Time the battery when you put it on the charger, meaning not to the second but what you would "normally" do is plug the battery into the charger and leave it right. Well what's possibly happening is that within ten minute the ready light is coming on, (something stupid going on in the battery) So check the battery stat of charge after say 15 minutes and if it says it ready (drum roll please) remove the battery unplug the charger for a few seconds and place the battery charger back onto the wall outlet and plug the battery back into the charger and look at your watch again. I've had to do this as much as three times until the thing would get the idea it was to take a charge "normally" about 2 hours will bring it back up. There is no device I've found to completely drain one of these batteries so over a period of time in your case one year the batteries begin this fit. I've since replaced the BP511 for the better BP511A's or equivalent. I'm not pointing a finger because myself and staff do the same thing and pull the battery before going to a shoot if it's showing partial discharge and the thing gets put onto charge and we start this cycle all over again. Be careful of the charger as well meaning don't just disconnect the battery and put it back on charge when it's going the cycle thing disconnect the charger from its power source as well because it holds a memory for a few seconds and will just shut off in a few moments if you don't.
Long story but I've been doing this now for 9 years since the dawn of Canon's 30D Cheers
Jan 16, 2011 | Canon PowerShot G5 Digital Camera
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
try removing the battery for 24 hours and allow the battery to charge for that long as well unless you charge the battery in the camera with a docking station then just leave it out also take a good look at the lcd when you try and turn it on see if the image is really dark but their is still a image. one this that I have noticed while working on casio is that a lens error can cause the lcd to be very dark and you can barley see a image but it is there so it causes you to thing the camera is dead. If you do see a image then the problem lies inside and needs to be serviced but if you don't then it lies in the power source. ie battery or power circuit of the camera. after the battery shows charged have it tested with a ohm meter it can help determine if it is a good battery. you can have it checked sometimes at radio shack or a place called batteries plus if you do not have one. I hope this helps out I know it can be frustrating but it happens. good luck.
Feb 03, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
243 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
