Try cleaning the lock itself then lubricating it and work the { boot / trunk }until it works in a bit ...does it appear as if it needs an adjustment ..as you close it do the lock and the striker match up within a reasonable catch distance otherwise an adjustment can be made .
the light will stay on if the switch does not make the necessary closed position allowing the circuit to remain open .again this would require an adjustment
has the vehicle been in an accident or the trunk disturbed to cause this ?
if not perhaps the switch itself needs an adjustment or is worn can the switch plate be lowered by bending the plate or can you adjust it otherwise .
